Count Rendering (Spatial Statistics) |
Release 9.2
Last modified January 9, 2009 |
Print all topics in : "Tools" |
Applies graduated circle rendering to a count type field of a point feature class.
Illustration
Usage tips
The Count Renderer draws quantities using circle size to show relative values.
By rendering features quantitatively, the point renderer displays potential patterns in the input count data.
This tool is appropriate for rendering output from the Collect Events tool.
Current map layers may be used to define the input feature class. When using layers, only the currently selected features are used in the Count Renderer operation.
This tool will only work on the windows operating system.
The environment settings do not affect this tool.
Command line syntax
An overview of the Command Line window
CountRenderer_stats <Input_Feature_Class> <Field_to_Render> <Output_Layer_File> <Number_of_Classes> <mango | bright_red | dark_green | green | dark_blue | bright_pink | light_yellow | sky_blue> {Maximum_Field_Value}
| Parameter | Explanation | Data Type |
| <Input_Feature_Class> |
The feature class containing count data to be rendered. |
Feature Layer |
| <Field_to_Render> |
The name of the field containing count data. |
Field |
| <Output_Layer_File> |
The output layer file to store rendering information. You must include the .lyr extension as part of the file name. |
Layer File |
| <Number_of_Classes> |
The number of classes into which the input feature class will be classified. |
Long |
| <mango | bright_red | dark_green | green | dark_blue | bright_pink | light_yellow | sky_blue> |
The color of the graduated circles. |
String |
| {Maximum_Field_Value} |
The maximum attribute value that will be rendered. Features with field values greater than this maximum value will not be drawn. |
Double |
workspace e:\project93\data CollectEvents assaults.shp assaults_weight.shp CountRenderer assaults_weight.shp COUNT assaults.lyr 8 bright_red #
Scripting syntax
About getting started with writing geoprocessing scripts
CountRenderer_stats (Input_Feature_Class, Field_to_Render, Output_Layer_File, Number_of_Classes, Symbol_Color, Maximum_Field_Value)
| Input_Feature_Class (Required) |
Feature Layer |
| Field_to_Render (Required) |
Field |
| Output_Layer_File (Required) |
Layer File |
| Number_of_Classes (Required) |
Long |
| Symbol_Color (Required) |
String |
| Maximum_Field_Value (Optional) |
Double |
# Convert incident data to weighted point data and render
# Import system modules
import arcgisscripting, sys, string, os
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Local variables...
workspace = "C:/project93/data/"
input = "AutoTheft.shp"
input_weighted = "autotheft_weighted.shp"
results_field = "Count"
input_weighted_rendered = "auto_weight_rendered.lyr"
try:
# Set the current workspace (to avoid having to specify the full path to the feature classes each time)
gp.workspace = workspace
# Process: Collect Events...
gp.CollectEvents_stats(input, input_weighted, results_field)
# Process: Count Rendering...
gp.CountRenderer_stats(input_weighted, results_field, input_weighted_rendered, "5", "mango", "#")
except:
# If an error occurred when running the tool, print out the error message.
print gp.GetMessages()
