You are here:
Geoprocessing tool reference
Environment Settings
General settings
NOTE: This environment is only applicable to ArcGIS 9.2, or higher.
Specify the Z tolerance that will be used for processing and set to the output geodataset.
Learn more about Z tolerance
Usage tips
- If the output is a feature class inside a feature dataset, the environment will be ignored because all feature classes inside a feature dataset must have the same Z tolerance.
- If the output is a standalone feature class, raster catalog or feature dataset, the tolerance of the input will be used as the processing and set as the output feature class' Z tolerance. For tools that have multiple inputs (Intersect for example), the tolerance of the first input in the list will be used as the default. To override these defaults, set the Z tolerance environment to the desired value.
- If the geoprocessing tool does not have an input geodataset (for example, Create Feature Class, Create Feature Dataset, and Create Raster Catalog) and if the environment is left blank, the default Z tolerance is set to 0.001 units. To override this default, set the environment to the desired value.
- If the tolerance is set to "Unknown" units, the units are assumed to be the same as the output vertical coordinate system's units.
- If the Z tolerance is not at least twice as large as the Z resolution value, the Z tolerance is set to be twice as large as the Z resolution by default.
- Tolerance will not be persisted to a dataset in a pre-92 geodatabase.
Learn more about specifying general settings
Learn more about environment settings
Learn more about environment levels and hierarchy
Command line syntax
An overview of the command line window
ZTolerance <linear unit>
| <Linear unit> |
The tolerance for adjusting Z values during cluster processing.
The default value is 10 * the Z resolution. |
Linear Unit |
Data types for geoprocessing tool parameters
Command line example
ZTolerance 0.02
Scripting syntax
An overview of scripting in geoprocessing
ZTolerance (Linear unit)
| Linear Unit (Required) |
Linear Unit |
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "H:\\Tongass"
gp.ZTolerance = "0.02"
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
