You are here:
Geoprocessing tool reference
Environment Settings
Geodatabase settings
Configuration keywords represent a setting or group of settings that tell the geodatabase where or in what format to store data contents in each dataset.
Configuration keywords are only used with file geodatabases or ArcSDE Enterprise Edition geodadatabases; they cannot be specified for personal geodatabases or ArcSDE Personal or Workgroup Edition geodatabases.
Usage tips
- The keyword used at the command line or in scripts for this environment setting is ConfigKeyword.
- In most cases, simply choosing the DEFAULT option will create new datasets that will work well for you. However, there are many cases in which you will need to specify a configuration keyword.
- Configuration keywords are used with File Geodatabases and with ArcSDE Geodatabases. Each of these geodatabase types has its own set of keywords. In the case of ArcSDE geodatabases, there are a number of configuration keywords that can be used for specifying geometry storage (which varies by DBMS), as well as for managing geometric networks and topologies.
- The following keywords are available when creating a feature class or table in a file geodatabase:
Defaults—Allows datasets to be up to 1 TB in size, stores text attribute data in UTF8 format, and compresses geometry.
Text_UTF16—Stores text attribute data in UTF16 format. If you are creating a file geodatabase feature class that will contain attribute data in Chinese, Russian, or another language with non-latin characters, you can specify this keyword so the text characters store in UTF16, a more efficient storage format for these languages.
Max_File_Size_4GB—Allows datasets to be up to 4 GB in size.
Max_File_Size_256TB—Allows datasets to be up to 256 TB in size. If you are importing an extremely large image into a file geodatabase, you can specify the MAX_FILE_SIZE_256TB configuration keyword, which tells the geodatabase to allow the raster dataset to be up to 256 terabytes in size.
GEOMETRY_UNCOMPRESSED—If you want to add a raster dataset to an ArcSDE for Oracle geodatabase, you could specify the SDO_GEOMETRY configuration keyword, which tells the database to store the rasters in Oracle GeoRaster format.
Learn more about file geodatabase configuration keywords
- There are many more options for configuration keywords in an ArcSDE Enterprise Edition geodatabase than in a file geodatabase. The configuration keywords that exist by default will vary depending on what type of DBMS you are using to store the data. See your system administrator for exact settings. Learn more about ArcSDE Enterprise Edition configuration keywords
Learn more about geodatabases
Learn more about specifying geodatabase settings
Learn more about environment settings
Learn more about environment levels and hierarchy
Command line syntax
An overview of the command line window
CONFIGKeyword <String>
| <String> |
Specifies the default storage parameters (configuration) for file geodatabases or a geodatabase in a relational database management system (RDBMS) accessed through ArcSDE.
Configuration keywords are only used with file geodatabases or ArcSDE Enterprise Edition geodatabases.
String |
Data types for geoprocessing tool parameters
Command line example
CONFIGKeyword storage_keyword
Scripting syntax
An overview of scripting in geoprocessing
CONFIGKeyword (string)
| string (Required) |
Specifies the default storage parameters (configuration) for file geodatabase or a geodatabase in a relational database management system (RDBMS) accessed through ArcSDE.
String |
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.Workspace = "sde.sde\\gp.GP.redlands"
gp.CONFIGKeyword = "storage_keyword"
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
