You are here:
Geoprocessing tool reference
Environment Settings
Geodatabase settings
Allowable coordinate range for .
Usage tips
- Unlike XY and Z domain, the M domain of a feature class inside a feature dataset is not constrained to match the feature dataset's M domain. For feature classes created inside a feature dataset, the feature dataset's M domain is used as the default. To override this default, set the M Domain environment to the desired range.
- If the M Resolution environment is set as well as the M Domain environment, the resolution value is used in combination with the domain's minimum value.
- It is recommended that you use the M Resolution in conjunction with the M Domain environment to avoid creating a dataset with extremely small resolution value. Extremely small resolution value can lead to a deterioration of performance.
- The keyword used at the command line or in scripts for this environment setting is MDomain.
Learn more about specifying geodatabase settings
Learn more about environment settings
Learn more about environment levels and hierarchy
Learn more about geodatabases
Command line syntax
An overview of the command line window
mdomain <value>
| <value> |
Allowable coordinate range for m- (measure) values. The m domain requires the following values:
- M Min—Minimum m- (measure) value.
- M Max—Maximum m- (measure) value.
String |
Data types for geoprocessing tool parameters
Command line example
MDomain "9689921.98576562 27282108.0219896"
Scripting syntax
An overview of scripting in geoprocessing
mdomain (value)
| value (Required) |
String |
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.MDomain = "27282108.0219896 27282108.0219896"
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
