About tabular data sources |
Release 9.2
Last modified December 18, 2007 |
Print all topics in : "Understanding tables and attribute information" |
ArcGIS allows you to work with data from a variety of sources. You can view tabular information in ArcMap and in ArcCatalog. The source of the data may determine the level of functionality that is available, though. For example, text files and data accessed through an OLE DB database connection are read-only in ArcGIS.
The table below contains information about different tabular data sources and what you can do with them in ArcGIS.
| Data source | Notes |
| Geodatabase (personal, file, and multiuser) | Create, delete, read, write. ArcInfo or ArcEditor is required to create or edit tables in ArcSDE geodatabases. |
| Feature layer attribute tables | Attribute tables are automatically created when the feature class is created. Assuming the feature class is writeable, its attribute table is also writeable. |
| dBASE | Create, delete, read, write. Some field types, such as Raster or BLOB, are not supported in dBASE tables or shapefile attribute tables. |
| INFO | Create (requires ArcInfo or ArcEditor), delete, read. INFO tables and coverage feature class attribute tables cannot be edited in ArcGIS Desktop. |
| Microsoft Excel | Read when accessed directly in ArcGIS or through OLE DB. |
| Microsoft Access (when not a geodatabase) | Read when accessed through OLE DB |
| Other data sources accessed through OLE DB | Read |
| Text files | Read |
