Working with variable-depth masking |
Release 9.2
Last modified August 15, 2007 |
Print all topics in : "Applying symbology" |
The term mask means to conceal from view or to hide. In ArcMap, variable-depth masking is a drawing technique for hiding parts of one or more layers.
One common use for masking is to clarify the legibility of a map that is densely packed with text and feature symbology. You can create a polygon mask layer based on an annotation layer, then mask out some feature symbology to make the map more readable. With variable-depth masking, only some layers are hidden by the masks. In the contour map example shown below, the contour line labels and the contour lines run together. However, when using a mask for the text annotation, those sections of contour lines are hidden, but elevation shading appearing behind those layers is still visible.
Masking will be maintained on any of the ESRI-supported map export formats.
There are several geoprocessing tools you can use to create masks. For more information, follow these links:
Cul-de-Sac Masks
Feature Outline Masks (described in more detail below)
Intersecting Layers Masks
NOTE: The Cartography tools are available in ArcInfo only; they are not available in ArcView or ArcEditor.
You can use any polygon feature class to create masks. This feature class must be added to your map as a layer in the table of contents.
From a data frame's Advanced Drawing Options dialog box, you can turn the masking on or off by checking or unchecking the box to Draw using masking options specified below.
The masking layers can also be set to mask one or more layers. Each layer to be masked can be checked in the Masked Layers list when the mask layer is highlighted in the Masking Layers list.
When creating masks, it is important to know that adding masks to maps adds complexity that will slow map drawing and affect map printing and exporting. Generally, there are three things to consider when creating masks for a map: (1) the number of masks, (2) the complexity of the masks, and (3) whether or not the masks will be used to mask polygon features filled with marker or line symbols. An increase in the number of masks, having more complex masks, and/or masking against marker or polygon fill symbols will result in slower drawing on your screen. Additionally, printing and exporting performance can be poor and even fail to produce valid output, first, because of the large amount of processing required to print and export maps with masks, and second, because of known limitations in how graphic file formats store map export results that have many complicated masks.
When seeking to improve drawing performance as well as to improve printing and exporting performance and reliability, the most important guideline to follow is to use the simplest masks necessary for the purposes of your map. In particular, when masking annotation text, you will find that CONVEX_HULL type masks are sufficient for many map purposes. If you need more detailed text masks, then use the EXACT_SIMPLIFIED type. Generally, when masking a lot of text on a relatively large map, avoid using the EXACT type mask because it will create too many complicated masks to produce valid output efficiently.
