Show Navigation | Hide Navigation
You are here:
Extensions > Military Overlay Editor > The MOLE geodatabase schema
Importing existing data for use with MOLE
Release 9.2
Last modified February 27, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "The MOLE geodatabase schema"
Related Topics
ArcGIS and MOLE offer a variety of data import methods. As long as at the end of the import process, the data meets the minimum requirements for MOLE, you can use any of the import methods, then add the data to an ArcMap or ArcGlobe map using the Add MOLE Data toolbar button Add Mole Data button.
Adding data with this button allows the data to be symbolized according to the military specification you chose.
This topic provides:
Importing data using a combination of geoprocessing tools
In this procedure, you create an event layer from a table that contains a field named "X" and a field named "Y", convert the event layer to a feature class, then add MOLE fields to the feature class.
Step 1 - Create an event layer from a table that contains a field (column) named "X" and a field named "Y":
Step 2 - Convert the event layer to a feature class:
Step 3 -Add MOLE fields to a non-MOLE feature class:
Import data into ArcMap using the Display XY Data command
In this procedure, you use the Display XY Data command on a Microsoft Excel spreadsheet that has x and y fields and the minimum required fields for MOLE, then convert the spreadsheet to a feature class or shapefile (to pick up the required ArcGIS requirements), then re-import it.
Step 1 - Say you have a spreadsheet or a comma separated file, such as an .xls, .csv, or .txt file, with XY coordinate data that you want to use in MOLE.
Step 2 -Import the spreadsheet into ArcMap:
  1. If you haven't already, start up ArcMap and add the MOLE toolbar.
  2. Click the ArcMap Add Data button Add Data button.
  3. In the Add Data dialog box, navigate to your spreadsheet (.xls file), then double-click it.
  4. The table in your spreadsheet is listed in the Source tab of the ArcMap table of contents, as shown in the following image.
    TOC after spreadsheet is added
  5. In the table of contents, right-click the table (in the above image, you'd right-click Sample_spreadsheet$), then click Display XY Data.
  6. The Display XY Data dialog box appears.
  7. In the Specify the fields for the X and Y coordinates area, click the X Field drop-down menu to select the field name of the field that contains your X coordinate data. In our sample, the name of the field is "X".
  8. Click the Y Field drop-down menu to select the field name of the field that contains your Y coordinate data.
  9. Click OK.
  10. The table now appears in the Display tab of the ArcMap table of contents.
  11. In the Display tab of the table of contents, right-click the table and click Data > Export Data.
  12. In the Export Data dialog box, in the Output shapefile or feature class area, click the Browse button Open.
  13. In the Saving Data dialog box:
  14. In the Export Data dialog box, click OK.
  15. The table is exported to the file format you selected. You can now add it as a layer in ArcGIS and it will display military symbology at the X and Y locations in your spreadsheet.
Additional import methods
For this import method See the instructions in
Typical ArcGIS import methods - Import feature classes
- Importing tables
- Importing datasets
- Import raster datasets
- Import from an XML workspace document
- Use a wizard to load data in ArcCatalog
- Use a wizard to load data in ArcMap
Add MOLE fields to one non-MOLE feature class or shapefile at a time using the Add MOLE Fields Single (Military Overlay Editor) geoprocessing tool For detailed field descriptions, see the help provided with the tool (in the tool's dialog box).
For help getting started with the tool, see Chapter 3 of the MOLE getting started guide.
For descriptions of the geoprocessing tools that come with MOLE, see Editing MOLE data using ArcToolbox.
Add MOLE fields to more than one non-MOLE feature class or shapefile at once For detailed field descriptions, see the help provided with the tool (in the tool's dialog box).
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
