You are here:
Editing and data compilation
Creating new features
About creating a fillet curve between two lines
are segments of a circular arc that are often used to connect two intersecting lines. Fillets are used to create smoothly curving connections between lines, such as edge of pavement lines at street intersections or rounded corners on parcel features.
The Fillet tool
creates a circular curve that is tangential to two line segments and optionally trims the overlapping segments from the original feature or features.
The curve is constructed using an implied or fixed radius value through the tangent points that are derived from a hint point, which is the mouse pointer location. It determines the region used to define the curve direction.
Press the O key to set the Fillet tool options. The options include whether or not to trim the existing features and use a fixed radius value.
How to create a fillet curve between two lines
- Click the Fillet tool
on the Advanced Editing toolbar.
- Optionally, press O to set the Fillet Options.
Check Trim existing segments if you want to remove the existing segments that extend beyond the tangent points.
Check Fixed radius and type a radius for the curve.
Press Enter or click OK.
- Click one line first, then the other, to specify the lines between which you want to construct the fillet.
Without a fixed radius, the fillet curve changes as you drag the pointer away from the first line you clicked.
- When the curve looks like it has the correct radius, click to finish the curve.
A new fillet curve joins the two selected lines. The extra line segments outside the curve are trimmed off if you checked Trim existing segments.
- The Fillet Options dialog box will use the current data frame coordinate system units for the fillet radius unless you specify another unit of measure when you type the fillet radius.
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
