Reclass by Table |
Release 9.2
Last modified January 3, 2008 |
Print all topics in : "Reclass (Spatial Analyst)" |
Reclassifies or changes the values of the input cells of a raster using a remap table.
Usage tips
Command line and Scripting
The input raster must have valid statistics. If the statistics do not exist, they can be created in two ways. The first is to right-click the raster in ArcCatalog and click Calculate Statistics. The other is to open the Data Management Tools toolbox, Raster toolset, Calculate Statistics tool in ArcToolbox.
The from value field, to value field, and output value field are the field names in the table that define the remapping.
To reclassify individual values, use a simple remap table of two items. The first item identifies the value to reclassify, and the other item identifies the value to assign to it. Set the to value field the same as the from value field. The value to assign to the output is output value field.
To reclassify ranges of values, the remap table must have items defining the start and end of each range, along with the value to assign the range. The item defining the start of the range is the from value field, and the value defining the end of the range is the to value field. The value to assign to the output is output value field.
The remap table can be an INFO table, a .dbf file, an Access table, or a text file.
The values in the from and to fields can be any numerical item. The assignment values in the output field must be integers.
Values in the from field of the table must be sorted in ascending order and should not overlap.
The output raster will always be of integer type.
The following environment settings affect this tool:
Command line syntax
An overview of the Command Line window
ReclassByTable_sa <in_raster> <in_remap_table> <from_value_field> <to_value_field> <output_value_field> <out_raster> {DATA | NODATA}
| Parameter | Explanation | Data Type |
| <in_raster> |
An input raster. The values contained in this raster will be the values to be reclassified. |
Composite Geodataset |
| <in_remap_table> |
Table holding fields defining value ranges to be reclassified and the values they will become. |
Table View |
| <from_value_field> |
Field holding the beginning value for each value range to be reclassified. This is a numeric field of in_remap_table. |
Field |
| <to_value_field> |
Field holding the ending value for each value range to be reclassified. This is a numeric field of in_remap_table. |
Field |
| <output_value_field> |
Field holding the integer values to which each range should be changed. This is an integer field of in_remap_table. |
Field |
| <out_raster> |
The raster to be created. |
Raster Dataset |
| {DATA | NODATA} |
Denotes whether missing values in the reclass table retain their value or get mapped to NoData.
Boolean |
ReclassByTable_sa c:/data/ras_1 c:/data/ReclassTable FromFld ToFld New_name c:/data/final_1 DATA
Scripting syntax
About getting started with writing geoprocessing scripts
ReclassByTable_sa (in_raster, in_remap_table, from_value_field, to_value_field, output_value_field, out_raster, missing_values)
| in_raster (Required) |
| in_remap_table (Required) |
Table View |
| from_value_field (Required) |
Field |
| to_value_field (Required) |
Field |
| output_value_field (Required) |
Field |
| out_raster (Required) |
Raster Dataset |
| missing_values (Optional) |
Boolean |
# ReclassByTable.py
# Description:
# Reclassifies (or changes) the values of the input cells of a
# raster by using a remap table.
# Requirements: None
# Author: ESRI
# Date: Sept 6, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
# Set the input files
inRaster = "c:/data/ras_1"
reclassByTable = "c:/data/ReclassTable"
# Set the output raster name
outRaster = "c:/data/final_1"
# Check out ArcGIS Spatial Analyst extension license
gp.CheckOutExtension("Spatial")
# Process: ReclassByTable
gp.ReclassByTable_sa(inRaster, reclassByTable, "FromFld", "ToFld", "New_name", outRaster, "DATA")
except:
# If an error occurred while running a tool, then print the messages
print gp.GetMessages()
Map Algebra syntax
See Reclass
ArcObjects syntax
See Reclass
