Show Navigation | Hide Navigation
Central Feature (Spatial Statistics)
Release 9.2
Last modified January 9, 2009
E-mail This Topic Printable Version Give Us Feedback
Related Topics
Identifies the most centrally located feature in a point, line, or polygon feature class.
Learn more about how Central Feature works
Illustration
Central Feature illustration
Usage tips
Command line syntax
An overview of the Command Line window
CentralFeature_stats <Input_Feature_Class> <Output_Feature_Class> <Euclidean Distance | Manhattan Distance> {Weight_Field} {Self_Potential_Weight_Field}
Parameter Explanation Data Type
The feature class containing a distribution of features from which to identify the most centrally located feature.
Feature Layer
The feature class that will contain the most centrally located feature in the input feature class.
Feature Class
Specifies how distances are calculated when measuring concentrations.
  • Euclidean (as the crow flies) — The straight-line distance between two points.
  • Manhattan (city block) — The distance between two points measured along axes at right angles. Calculated by summing the (absolute) differences between point coordinates.
String
{Weight_Field}
The numeric field used to weight distances in the origin-destination distance matrix.
Field
The field representing self-potential — The distance or weight between a feature and itself.
Field
Data types for geoprocessing tool parameters
Command line example
CentralFeature e:\project93\data\hospitals.shp e:\project93\output\hosp_cf.shp 'Manhattan Distance' POP #
Scripting syntax
About getting started with writing geoprocessing scripts
CentralFeature_stats (Input_Feature_Class, Output_Feature_Class, Distance_Method, Weight_Field, Self_Potential_Weight_Field)
Input_Feature_Class (Required)
Feature Layer
Output_Feature_Class (Required)
Feature Class
Distance_Method (Required)
String
Weight_Field (Optional)
Field
Self_Potential_Weight_Field (Optional)
Field
Script example
# Measure geographic distribution characteristics of coffee house locations weighted by the number of employees
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Local variables...
workspace = "C:/data"
input_FC = "coffee_shops.shp"
CF_output = "coffee_CF.shp"
MC_output = "coffee_MC.shp"
weight_field = "NUM_EMP"
try:
    # Set the workspace to avoid having to type out full path names
    gp.workspace = workspace
    # Process: Central Feature...
    gp.CentralFeature_stats(input_FC, CF_output, "Euclidean Distance", weight_field, "#")
    # Process: Mean Center...
    gp.MeanCenter_stats(input_FC, MC_output, weight_field, "#", "#")
except:
    # If an error occurred when running the tool, print out the error message.
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
