Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Conversion toolbox > To Raster toolset > Tools
Float To Raster (Conversion)
Release 9.2
Last modified April 2, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Converts a file of binary floating-point values representing raster data to a raster dataset.
Usage tips
Command line syntax
An overview of the Command Line window
FloatToRaster_conversion <in_float_file> <out_raster>
Parameter Explanation Data Type
<in_float_file>
The input floating-point binary file. The file must have a .flt extension. There must be a header file in association with the floating-point binary file, with a .hdr extension.
File
<out_raster>
The raster dataset to be created.
When not saving to a geodatabase, specify .tif for a TIFF file format, .img for an ERDAS IMAGINE file format, or no extension for a GRID file format.
Raster Dataset
Data types for geoprocessing tool parameters
Command line example
FloatToRaster_conversion d:\data\whitehorse.mdb\elevation.flt d:\data\rasterdata.mdb\elevation
Scripting syntax
About getting started with writing geoprocessing scripts
FloatToRaster_conversion (in_float_file, out_raster)
in_float_file (Required)
File
out_raster (Required)
Raster Dataset
Script example
# FloatToRaster_sample.py
# Description:
#   Converts a file of binary floating point values
#   representing raster data to a raster.
# Requirements: None
# Author: ESRI
# Date: Oct 20, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
    # Set local variables
    InFloatFile = "C:/data/example.flt"
    OutRaster = "C:/data/raster1"
    # Process: FloatToRaster_conversion
    gp.FloatToRaster_conversion(InFloatFile, OutRaster)
except:
    # Print error message if an error occurs
    print gp.GetMessages()
Map Algebra syntax
See FloatGrid.
The Spatial Analyst extension must be present to use this link.
ArcObjects syntax
See ImportFromFloat.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
