Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Cartography toolbox > Symbolization Refinement toolset > Tools
Create Underpass (Cartography) (ArcInfo only)
Release 9.2
Last modified July 13, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Generates mask polygons at the intersections of stroke representations to symbolize one set of strokes passing under the other. Optionally, linear parapet features can be generated adjacent to these masks.
Illustration
Illustration of create underpass tool
Usage tips
Command line syntax
An overview of the Command Line window
CreateUnderpass_cartography <in_above_features> <in_below_features> <margin_along> <margin_across> <out_underpass_feature_class> <out_mask_relationship_class> {where_clause} {out_decoration_feature_class} {ANGLED | PARALLEL | NONE} {wing_tick_length}
Parameter Explanation Data Type
<in_above_features>
The input line feature layer containing stroke representations that intersect — and will be symbolized as passing above — stroke representations in the Input Below Features.
Layer
<in_below_features>
The input line feature layer containing stroke representations that intersect — and will be symbolized as passing below — stroke representations in the Input Above Features. These features will be masked by the polygons created in the Output Overpass feature class.
Layer
<margin_along>
Sets the length of the mask polygons along the Input Above Features by specifiying the distance in page units that the mask should extend beyond the width of the stroke symbol of the Input Below Features. The Margin Along must be specified, and it must be greater than or equal to zero. Choose a page unit for the margin; the default is points.
Linear unit
<margin_across>
Sets the width of the mask polygons across the Input Above Features by specifiying the distance in page units that the mask should extend beyond the width of the stroke symbol of the Input Below Features. The Margin Across must be specified, and it must be greater than or equal to zero. Choose a page unit for the margin; the default is points.
Linear unit
The output feature class that will be created to store polygons to mask the Input Below Features.
Feature Class
The output relationship class that will be created to store links between Underpass mask polygons and the stroke representations of the Input Below Features.
Relationship Class
{where_clause}
An SQL expression used to select a subset of features in the Input Below Features.
The syntax for the expression differs slightly depending on the data source. For example, if you're querying file or ArcSDE geodatabases, enclose field names in double quotes:
"MY_FIELD"
If you're querying personal geodatabases, enclose fields in square brackets:
[MY_FIELD].
For more information on SQL syntax and how it differs between data sources, see SQL Reference.
SQL Expression
The output line feature class that will be created to store parapet features.
Feature Class
Specifies the wing style of the parapet features.
  • ANGLED — specifies that the wing tick of the parapet will be angled between the Above features and the Below features. This is the default.
  • PARALLEL — specifies that the wing tick of the overpass wing will be parallel to the Below features.
  • NONE — specifies that no wing ticks will be created on the parapets.
String
{wing_tick_length}
Sets the length of the parapet wings in page units. The length must be greater than or equal to zero; the default length is 1. Choose a page unit (Points, Milimeters, and so on) for the length; the default is Points. This parameter does not apply to the Wing Type - NONE.
Linear unit
Data types for geoprocessing tool parameters
Command line example
CreateUnderpass_cartography c:\workspace.mdb\roads.lyr railroads.lyr 2 3 masksFC masks.rel underpassFC ANGLED 1
Scripting syntax
About getting started with writing geoprocessing scripts
CreateUnderpass_cartography (in_above_features, in_below_features, margin_along, margin_across, out_underpass_feature_class, out_mask_relationship_class, where_clause, out_decoration_feature_class, wing_type, wing_tick_length)
in_above_features (Required)
Layer
in_below_features (Required)
Layer
margin_along (Required)
Linear unit
margin_across (Required)
Linear unit
out_underpass_feature_class (Required)
Feature Class
out_mask_relationship_class (Required)
Relationship Class
where_clause (Optional)
"MY_FIELD"
[MY_FIELD].
SQL Expression
out_decoration_feature_class (Optional)
Feature Class
wing_type (Optional)
String
wing_tick_length (Optional)
Linear unit
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "c:\Workspace.mdb"
gp.toolbox = "cartography"
gp.CreateUnderpass("roads.lyr", "railroads.lyr", 2, 3, "masksFC", "masks.rel", "underpassFC", "ANGLED", 1)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
