Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Coverage toolbox > Data Management toolset > Items toolset > Tools
Add Item (Coverage) (ArcInfo only)
Release 9.2
Last modified February 6, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
NOTE: This tool only works with an ArcInfo license and will only be available in ArcToolbox if you have installed ArcInfo Workstation.
Adds a blank or zero item to an INFO table.
Usage tips
Command line syntax
An overview of the Command Line window
AddItem_arc <in_info_table> <out_info_table> <item_name> <item_width> <output_width> <BINARY | CHARACTER | DATE | FLOATING | INTEGER | NUMERIC> {decimal_places} {start_item}
Parameter Explanation Data Type
<in_info_table>
The INFO table to which the item is to be added.
ArcInfo Table
<out_info_table>
The INFO table to be created.
ArcInfo Table
<item_name>
The item to be added to the INFO table.
String
<item_width>
The INFO width of the added item. Supported widths:
  • BINARY — Either 2 or 4 bytes
  • CHARACTER — 1 to 320 characters
  • DATE — Always 8 bytes; stored as mm/dd/yy
  • FLOATING — Either 4 (single precision) or 8 bytes (double precision)
  • NUMERIC — 1 to 16 digits
  • INTEGER — 1 to 16 digits
Long
<output_width>
The output width of the added item. This is the number of characters used to display an item value.
For example, in a 2-byte integer (item type BINARY), values can be as high as 32767, which requires five characters for display. Dates can be displayed using eight (mm/dd/yy) or ten (mm/dd/yyyy) characters. For international date displays, months and days can be switched (for example, dd/mm/yy).
Long
The INFO item type of the added item.
  • BINARY — Binary integer, requires less storage than integer
  • CHARACTER — Text
  • DATE — Date; stores day, month, and year
  • FLOATING — Floating-point binary number, either single or double precision
  • NUMERIC — Decimal number stored as one byte per digit
  • INTEGER — Integer number stored as one byte per digit
String
{decimal_places}
The number of decimal places for the added item. This needs to be specified for INFO item types NUMERIC and FLOATING.
Long
{start_item}
The item in the in_info_table after which the new item is to be added. The default start_item is the last item in the in_info_table.
ArcInfo Item
Data types for geoprocessing tool parameters
Command line example
AddItem C:\data\polygon C:\data\polygon sites 25 25 CHARACTER
Scripting syntax
About getting started with writing geoprocessing scripts
AddItem_arc (in_info_table, out_info_table, item_name, item_width, output_width, item_type, decimal_places, start_item)
in_info_table (Required)
ArcInfo Table
out_info_table (Required)
ArcInfo Table
item_name (Required)
String
item_width (Required)
Long
output_width (Required)
Long
item_type (Required)
  • CHARACTER — Text
String
decimal_places (Optional)
Long
start_item (Optional)
ArcInfo Item
Script example
# Add an item to an Info table
# Import system modules
import arcgisscripting, sys, string, os
gp = arcgisscripting.create()
# Local variables...
workspace = "c:/project93/data/"
input_table = "tra_airpor/polygon"
output_table = "tra_airpor/polygon"
try:
    # Set the current workspace (to avoid having to specify the full path to the feature classes each time)
    gp.workspace = workspace
    # Process: Add Item...
    gp.AddItem_arc(input_table, output_table, "sites", "4", "5", "BINARY", "", "")
except:
    # If an error occurred when running the tool, print out the error message.
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
