Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Data Comparison toolset > Tools
TIN Compare (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Compares two TINs and returns the comparison results. TIN Compare can report differences with geometry, TIN node and triangle tags, and spatial reference.
Usage tips
Command line syntax
An overview of the Command Line window
TINCompare_management <in_base_tin> <in_test_tin> {ALL | PROPERTIES_ONLY | SPATIAL_REFERENCE_ONLY} {NO_CONTINUE_COMPARE | CONTINUE_COMPARE} {out_compare_file}
Parameter Explanation Data Type
<in_base_tin>
The Input Base Tin is compared with the Input Test Tin. Input Base Tin refers to your data that you have declared valid. This base data has the correct geometry, tag values (if any), and spatial reference.
Tin Layer
<in_test_tin>
The Input Test Tin is compared against the Input Base Tin.
Tin Layer
The comparison type.
  • ALL — This is the default.
  • PROPERTIES_ONLY — Refers to both geometry and TIN tag values, if any, that are assigned to nodes and triangles.
  • SPATIAL_REFERENCE_ONLY — Coordinate system information.
String
Indicates whether to compare all properties after encountering the first mismatch.
  • NO_CONTINUE_COMPARE — Stop after encountering the first mismatch. This is the default.
  • CONTINUE_COMPARE — Compare other properties after encountering the first mismatch.
Boolean
{out_compare_file}
The name and path of the text file which will contain the comparison results.
File
Data types for geoprocessing tool parameters
Command line example
TINCompare_management c:\workspace\basetin c:\workspace\newtin ALL CONTINUE_COMPARE C:\workspace\tincompare.txt
Scripting syntax
About getting started with writing geoprocessing scripts
TINCompare_management (in_base_tin, in_test_tin, compare_type, continue_compare, out_compare_file)
in_base_tin (Required)
Tin Layer
in_test_tin (Required)
Tin Layer
compare_type (Optional)
String
continue_compare (Optional)
Boolean
out_compare_file (Optional)
File
Script example
# TinCompare.py
# Description: Compare two TINs and return comparison result.
# Requirements: None
# Author: ESRI
# Date: 11/16/05
# Create the Geoprocessing Object
import arcgisscripting, sys, os
gp = arcgisscripting.create()
try:
    # Set local variables
    base_tin= "C:/Workspace/basetin"
    test_tin= "C:/Workspace/newtin"
    compare_type = "ALL"
    continue_compare = "CONTINUE_COMPARE"
    compare_file = "C:/Workspace/tincompare.txt"
    # Process: TinCompare
    compare_result = gp.TinCompare_management(base_tin, test_tin, compare_type, continue_compare, compare_file)
    print compare_result
    print gp.GetMessages()
except:
    # Print error message if an error occurs
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
