Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Distributed Geodatabase toolset > Tools
Export Data Change Message (Data Management) (ArcInfo and ArcEditor only)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Creates an output delta file containing updates from an input replica.
Learn more about data synchronization
Learn more about disconnected data synchronization
Usage tips
Command line syntax
An overview of the Command Line window
ExportDataChangeMessage_management <in_geodatabase> <out_data_changes_file> <in_replica> {switch_to_receiver} {include_unacknowledged_changes} {include_new_changes}
Parameter Explanation Data Type
<in_geodatabase>
Specifies the replica geodatabase from which to export the data change message from. The geodatabase may be local or remote.
Workspace | GeoDataServer|GPComposite
Specifies the delta file to export to.
File
<in_replica>
The replica containing updates to be exported.
String
Indicates whether to change the role of the replica to that of a receiver. The receiver may not send replica updates until updates from the relative replica sender arrive.
  • DO_NOT_SWITCH — Do not switch replica role. This is the default.
  • SWITCH — Switch replica role from sender to a receiver.
Boolean
Indicates whether to include data changes that have been previously exported for which no acknowledgement message has been recieved.
  • NO_UNACKNOWLEDGED — Do not include data changes that have previously been sent.
  • UNACKNOWLEDGED — Include all of the data changes that have been previously exported for which no acknowledgement message has been sent. This is the default.
Boolean
Indicates whether to include all data changes created since the last exported data change message.
  • NO_NEW_CHANGES — Do not include data changes created since the last exported data change message.
  • NEW_CHANGES — Include data changes created since the last exported data change message. This is the default.
Boolean
Data types for geoprocessing tool parameters
Command line example
ExportDataChangeMessage Countries.mdb d:\delta.mdb MyReplica1 TRUE FALSE TRUE
Scripting syntax
About getting started with writing geoprocessing scripts
ExportDataChangeMessage_management (in_geodatabase, out_data_changes_file, in_replica, switch_to_receiver, include_unacknowledged_changes, include_new_changes)
in_geodatabase (Required)
out_data_changes_file (Required)
File
in_replica (Required)
String
switch_to_receiver (Optional)
Boolean
include_unacknowledged_changes (Optional)
Boolean
include_new_changes (Optional)
Boolean
Script example
# Create the Geoprocessor object
import arcgisscripting, sys, scripting, os
gp = arcgisscripting.create()
# Set the necessary product code
gp.SetProduct("ArcInfo")
# Load required toolboxes...
gp.AddToolbox("Data Management Tools.tbx")
# Process: Export Data Change Message...
gp.ExportDataChangeMessage_management("Database Connections\Connection to workspace.sde", "d:\delta.mdb", "MyReplica1", "TRUE", "TRUE", "TRUE")
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
