Plate Carrée |
Release 9.2
Last modified August 3, 2007 |
![]() ![]() ![]() Print all topics in : "Supported map projections" |
Also known as Equirectangular, Equidistant Cylindrical, Simple Cylindrical, or Rectangular, this projection is very simple to construct because it forms a grid of equal rectangles. Because of its simple calculations, its usage was more common in the past. In this projection, the polar regions are less distorted in scale and area than they are in the Mercator projection.
This simple cylindrical projection converts the globe into a Cartesian grid. Each rectangular grid cell has the same size, shape, and area. All the graticular intersections are 90°. The traditional Plate Carrée projection uses the equator as the standard parallel. The grid cells are perfect squares. In this projection, the poles are represented as straight lines across the top and bottom of the grid.
Tangent at the equator.
All meridians and all parallels.
Noticeable distortion of all properties away from standard parallels.
Best used for city maps or other small areas with map scales large enough to reduce the obvious distortion.
Used for simple portrayals of the world or regions with minimal geographic data. This makes the projection useful for index maps.
