Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Distributed Geodatabase toolset > Tools
Synchronize Changes (Data Management) (ArcInfo and ArcEditor only)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Synchronizes updates between 2 replica geodatabases in a direction specified by the user.
Learn more about data synchronization
Usage tips
Command line syntax
An overview of the Command Line window
SynchronizeChanges_management <geodatabase_1> <in_replica> <geodatabase_2> {FROM_GEODATABASE_1_TO_2 | FROM_GEODATABASE_2_TO_1 | BOTH_DIRECTIONS} {MANUAL | IN_FAVOR_OF_GDB1 | IN_FAVOR_OF_GDB2} {BY_OBJECT | BY_ATTRIBUTE} {reconcile}
Parameter Explanation Data Type
<geodatabase_1>
The geodatabase hosting the replica to synchronize. The geodatabase may be local or remote.
Workspace | GeoDataServer|GPComposite type
<in_replica>
A valid replica with a parent contained within one input geodatabase and a child in the other input geodatabase.
String
<geodatabase_2>
The geodatabase hosting the relative replica. The geodatabase may be local or remote.
The direction you want changes to be sent in: from geodatabase 1 to geodatabase 2, from geodatabase 2 to geodatabase 1, or to send changes in both directions. For check out/check in replicas or one way replicas there is only one appropriate direction. If the replica is two way then any of the three choices are available.
String
Specifies how conflicts are resolved when they are encountered.
MANUAL - manually resolve conflicts in the versioning reconcile environment.
IN_FAVOR_OF_GDB1- conflicts resolve in favor of the <geodatabase_1>.
IN_FAVOR_OF_GDB2- conflicts resolve in favor of the <geodatabase_2>.
String
Specifies how you would like to define conflicts: By Object or By Attribute. Defining conflicts by object will detect conflicts by row while defining them by attribute detects conflicts by column.
String
{reconcile}
Indicates whether to automatically reconcile once data changes are sent to the parent replica if there are no conflicts present. This option is only available for check out/check in replicas.
  • DO_NOT_RECONCILE — Do not reconcile. This is the default.
  • RECONCILE — Reconcile.
Boolean
Data types for geoprocessing tool parameters
Command line example
SynchronizeChanges d:\workspace.mdb MyReplica1 "Database Connections\Connection to workspace.sde" GEODATABASE_1_TO_2 IN_FAVOR_OF_GDB1 TRUE
Scripting syntax
About getting started with writing geoprocessing scripts
SynchronizeChanges_management (geodatabase_1, in_replica, geodatabase_2, in_direction, conflict_policy, conflict_definition, reconcile)
geodatabase_1 (Required)
in_replica (Required)
String
geodatabase_2 (Required)
in_direction (Optional)
String
conflict_policy (Optional)
String
conflict_definition (Optional)
String
reconcile (Optional)
Boolean
Script example
# Create the Geoprocessor object
import arcgisscripting, sys, scripting, os
gp = arcgisscripting.create()
# Set the necessary product code
gp.SetProduct("ArcInfo")
# Load required toolboxes...
gp.AddToolbox("Data Management Tools.tbx")
# Process: Synchronize Changes...
gp.SynchronizeChanges("d:\workspace.mdb", "MyReplica1", "Database Connections\Connection to workspace.sde", "GEODATABASE_1_TO_2", "IN_FAVOR_OF_GDB1", "TRUE")
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
