Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Features toolset > Tools
Adjust 3D Z (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Allows the modification of all Z values in a Z enabled Feature Class.
Usage tips
Command line syntax
An overview of the Command Line window
Adjust3DZ_management <in_features> {NO_REVERSE | REVERSE} {adjust_value} {MILLIMETERS | CENTIMETERS | METERS | INCHES | FEET | YARDS | FATHOMS} {MILLIMETERS | CENTIMETERS | METERS | INCHES | FEET | YARDS | FATHOMS}
Parameter Explanation Data Type
<in_features>
The input feature class containing Z-values in the SHAPE field.
Feature Layer
Flips the sign of all the Z values in the feature class.
String keyword
{adjust_value}
This parameters allows you to specify a value for a bulk shift. To decrease the z-values for the entire feature class, enter a negative number. To increase, enter a positive value.
Double
This parameter specifies the units that the z values will be converted from. Available conversion factors are:
    millimeters
    centimeters
    meters
    inches
    feet
    yards
    fathoms
This parameter is used in conjunction with Convert To Units.
String keyword
This parameter specifies the units that the z values will be converted to. Available conversion factors are:
    millimeters
    centimeters
    meters
    inches
    feet
    yards
    fathoms
This parameter is used in conjunction with Convert From Units.
String keyword
Data types for geoprocessing tool parameters
Command line example
Reverse Sign Example:
Adjust3DZ C:\Tutorial\sample_data.gdb\tutorial\depths REVERSE # #
Bulk Shift Adjustment Example:
Adjust3DZ C:\Tutorial\sample_data.gdb\tutorial\coastline # 10.5 # #
Unit Conversion Example:
Adjust3DZ C:\Tutorial\sample_data.gdb\tutorial\breaklines # # FEET METERS
Scripting syntax
About getting started with writing geoprocessing scripts
Adjust3DZ_management (in_features, reverse_sign, adjust_value, from_units, to_units)
in_features (Required)
Feature Layer
reverse_sign (Optional)
String keyword
adjust_value (Optional)
Double
from_units (Optional)
    millimeters
    centimeters
    meters
    inches
    feet
    yards
    fathoms
String keyword
to_units (Optional)
    millimeters
    centimeters
    meters
    inches
    feet
    yards
    fathoms
String keyword
Script example
# Name:         adjust3dz.py
# Description:  This python file tests the functionality of Adjust3DZ, specifically for:
#   1. REVERSE signs of Z-values in Z enabled multipoint feature class
#   2. BULK SHIFT of Z-values in Z enabled polyline feature class
#   3. COORDINATE CONVERSION of units in Z-enabled point feature class
# Requirements: Python and the Python win32all extension
# Author: ESRI
# Date 1/1/2009
# Create the Geoprocessor
import arcgisscripting, time
gp = arcgisscripting.create()
gp.overwriteoutput = 1
inFClass = "test_adjust.gdb\\topography\\multipoint_test"
signage = "REVERSE"
adjust = " "
from_units = " "
to_units = " "
print "Executing REVERSE Adjust3DZ test."
adjust3dz_management (inFClass, signage, adjust, from_units, to_units)
inFClass = "test_adjust.gdb\\topography\\breaklines"
signage = " "
adjust = "10.5"
from_units = " "
to_units = " "
print "Executing BULK_SHIFT Adjust3DZ test."
inFClass = "test_adjust.gdb\\topography\\points_test"
signage = " "
adjust = " "
from_units = "FEET"
to_units = "METERS"
print "Executing UNIT_CONVERSION Adjust3DZ test."
print "Finished Adjust3DZ tests."
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
