Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Fields toolset > Tools
Calculate Field (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Calculates the values of a field for a feature class, feature layer, or raster catalog.
The input table will be modified; a copy should be made to preserve the original information.
Usage tips
Command line syntax
An overview of the Command Line window
CalculateField_management <in_table> <field> <expression> {VB | PYTHON} {code_block}
Parameter Explanation Data Type
<in_table>
The table that contains the rows from a specified field that will be calculated. The updated values will be added to this table.
Table View | Raster Layer
<field>
The field that will be updated with the new calculation.
Field
<expression>
The simple calculation expression used to create a value that will populate the selected rows.
SQL Expression
{VB | PYTHON}
Specify the type of expression that will be used.
  • VB — The expression will be written in a standard VB format. This is the default.
  • PYTHON — The expression will be written in a standard Python format.
String
{code_block}
Allows for a block of code to be entered for complex expressions.
String
Data types for geoprocessing tool parameters
Command line example
CalculateField_management c:\test data\harvestable.shp Growth '[age] / [height]' VB
CalculateField_management c:\test data\harvestable.shp NEAR_X "!COUNT_X! / !SHAPE.AREA!" PYTHON #
CalculateField_management c:\test data\harvestable.shp NEAR_X x PYTHON 'x = 5'
CalculateField_management c:\test data\harvestable.shp NEAR_X x PYTHON 'import random;x = random.random()'
Scripting syntax
About getting started with writing geoprocessing scripts
CalculateField_management (in_table, field, expression, expression_type, code_block)
in_table (Required)
field (Required)
Field
expression (Required)
SQL Expression
expression_type (Optional)
String
code_block (Optional)
String
Script example
EXAMPLE 1: VB-based and Python-based Calculation
import arcgisscripting
gp = arcgisscripting.create()
# Set a default workspace
gp.workspace = "c:/test_data"
try:
    # Calculate field to a new value
    gp.CalculateField_management("harvestable.shp", "growth", "[age] / [height]", "VB")
    gp.CalculateField_management("harvestable.shp", "NEAR_X", "x", "PYTHON", "'import random;x = random.random()'")
except:
    # If an error occurs when running Addfield, print out the error message.
    print gp.GetMessages(2)
EXAMPLE 2:  PYTHON-based Calculation using geometry properties
# Calculate x and y centroid fields using the geometry property Centroid
import arcgisscripting, sys
inputFC = sys.argv[1]
gp.AddField_management(inputFC, "xCentroid", "DOUBLE", 18, 11)
gp.AddField_management(inputFC, "yCentroid", "DOUBLE", 18, 11)
# Centroid property returns a string with x and y separated by a space
xExpression = "float(!SHAPE.CENTROID!.split()[0])"
yExpression = "float(!SHAPE.CENTROID!.split()[1])"
gp.CalculateField_management(inputFC, "xCentroid", xExpression, "PYTHON")
gp.CalculateField_management(inputFC, "yCentroid", yExpression, "PYTHON")
EXAMPLE 3: PYTHON-based Calculation using codeblock parameter
# Calculate an area class based on the size of polygons
# An input polygon feature class
gp.AddField_management(inputFC, "areaclass", "short")
# Calculation is based on a custom getclass definition
expression = "getclass(float(!shape.area!))"
codeblock = "def getclass(area):        if area <= 1000:            return 1        if area > 1000 and area <= 10000:            return 2        else:            return 3"
gp.CalculateField_management(inputFC, "areaclass", expression, "PYTHON", codeblock)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
