Merge Branch (Data Management) |
Release 9.2
Last modified November 29, 2010 |
![]() ![]() ![]() Print all topics in : "Tools" |
NOTE: This tool is intended for use only in ModelBuilder.
This tool will merge two or more logical branches into a single output.
Illustration
Usage tips
The tool looks at the list of inputs variables and returns the first variable that is in the 'has been run' state.
This tool outputs a variant which can be used as the feedback variable to any other input data element in the model.
No environment settings affect this tool.
Command line syntax
An overview of the Command Line window
MergeBranch_management <in_values;in_values...>
Parameter | Explanation | Data Type |
<in_values;in_values...> |
List of values to be checked for currency. The first "ready to run" state value in the list will be the output of the tool. |
Any value |
Scripting syntax
About getting started with writing geoprocessing scripts
MergeBranch_management (in_values)
in_values (Required) |
Any value |
