Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Projections and Transformations toolset > Feature Tools
Project (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Feature Tools"
Related Topics
Changes the coordinate system of your Input Dataset or Feature Class to a new Output Dataset or Feature Class with the newly defined coordinate system, including the datum and spheroid.
Usage tips
Command line syntax
An overview of the Command Line window
Project_management <in_dataset> <out_dataset> <out_coor_system> {transform_method;transform_method...} {in_coor_system}
Parameter Explanation Data Type
<in_dataset>
The feature class whose coordinates are to be converted.
Feature Layer | Feature Dataset
<out_dataset>
The feature class whose coordinates have been converted into the new coordinate system.
Geodataset
<out_coor_system>
The coordinate system to be applied to the Output Dataset or Feature Class.
Coordinate System
A method for converting data between two geographic coordinate systems or datums. For more information on geographic transformations, see Geographic transformation methods.
String
{in_coor_system}
The coordinate system of the Input Dataset or Feature Class.
Coordinate System
Data types for geoprocessing tool parameters
Command line example
Project_management c:\test_data\dams C:\test_data\dams_projected.shp 'Coordinate Systems\Projected Coordinate Systems\Utm\Nad 1927\NAD 1927 UTM Zone 14N.prj'  NAD_1927_To_NAD_1983_NTv2_Canada
Scripting syntax
About getting started with writing geoprocessing scripts
Project_management (in_dataset, out_dataset, out_coor_system, transform_method, in_coor_system)
in_dataset (Required)
out_dataset (Required)
Geodataset
out_coor_system (Required)
Coordinate System
transform_method (Optional)
String
in_coor_system (Optional)
Coordinate System
Script example
# Create the Geoprocessor Object
import arcgisscripting
gp = arcgisscripting.create()
# Set the workspace
GP.workspace = "c:/Test_data/Personal GDB/canada.mdb"
# Set the Toolbox
GP.toolbox = "management"
# Set the spatial reference variable
cs = "C:/ArcGIS/Coordinate Systems/Geographic Coordinate Systems/North America/North American Datum 1983.prj"
# Run tool in a try and except
try:
    GP.project (GP.workspace + "/prov/province_buffer1", "province_buffer5", cs, "NAD_1927_To_NAD_1983_NTv2_Canada")
except:
    print GP.GetMessages(2)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
