Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Projections and Transformations toolset > Raster Tools
Rotate (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Raster Tools"
Related Topics
Turns the raster dataset around the specified pivot point by angle specified in degrees; the raster dataset will rotate in a clock-wise rotation.
Valid values for the rotation angle is any number from zero to 360; including floating point values. A negative value will rotate the image in a counter-clockwise rotation.
Illustration
Rotate illustration
Usage tips
Command line syntax
An overview of the Command Line window
Rotate_management <in_raster> <out_raster> <angle> {pivot_point} {NEAREST | BILINEAR | CUBIC}
Parameter Explanation Data Type
<in_raster>
The input raster dataset.
Composite Geodataset
<out_raster>
Output raster dataset.
When storing the raster dataset in a file format, you need to specify the file extension: .img for an ERDAS IMAGINE file, .tif for TIFF, or no extension for GRID.
When storing a raster dataset in a geodatabase, no file extension should be added to the name of the raster dataset. A raster dataset stored in a geodatabase can be compressed; you can specify a compression type and compression quality.
Raster Dataset
<angle>
The angle in degrees to rotate the raster. This can be any floating-point number.
Double
{pivot_point}
The pivot point around which to rotate the raster. The default is the lower left corner of the input raster dataset. To add this variable, press F8 or right-click and click Insert Variable.
Point
The resampling algorithm to be used.
  • NEAREST — Nearest neighbor assignment (the default)
  • BILINEAR — Bilinear interpolation
  • CUBIC — Cubic convolution
String
Data types for geoprocessing tool parameters
Command line example
rotate_management d:\images\MyImages.mdb\flowers d:\images\NewImages.mdb\flowers 45 pivot_point1 CUBIC
Scripting syntax
About getting started with writing geoprocessing scripts
Rotate_management (in_raster, out_raster, angle, pivot_point, resampling_type)
in_raster (Required)
out_raster (Required)
Raster Dataset
angle (Required)
Double
pivot_point (Optional)
Point
resampling_type (Optional)
String
Script example
# RasterTransformation_rotate.py
# Description: Rotates a raster around the specified pivot point by
#              an angle specified in degrees.
# Requirements: None
# Author: ESRI
# Date: 12/22/03
# Create the Geoprocessor object
import arcgisscripting
gp = arcgisscripting.create()
try:
    # Set the input raster dataset name
    inputRaster = "C:/data/ingrid"
    # Set the output raster name
    outputRaster = "C:/data/outgrid"
    # Specify the pivot point
    PivotPoint = "100 100"
    # Process: Rotate, specify the pivot point or use default
    #  gp.Rotate_management(inputRaster, outputRaster, "45")
    gp.Rotate_management(inputRaster, outputRaster, "45" ,PivotPoint, "BILINEAR")
except:
    # If an error occurred while running a tool, then print the messages
    print gp.GetMessages()
Map Algebra syntax
Rotate(<in_grid>, <angle>, {NEAREST | BILINEAR | CUBIC})
<in_grid> The name of the raster to be rotated.
<angle> The angle of rotation.
{NEAREST | BILINEAR | CUBIC} The resampling algorithm to be used when rotating a raster.
  • NEAREST - Nearest-neighbor assignment. This is the default.
  • BILINEAR - Bilinear interpolation.
  • CUBIC - Cubic convolution.
See "Resample" in Using Spatial Analyst for a description of the resampling methods.
Map Algebra example
rotate(ingrid)
rotate(ingrid, 45)
rotate(ingrid, 101.25, cubic)
ArcObjects syntax
There is no corresponding ArcGIS Spatial Analyst object to perform Rotate. However, in core ArcGIS, similar functionality can be found in the IRasterGeometryProc object.
For more information, see ArcObjects Developer Help.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
