Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Versions toolset > Tools
Unregister as Versioned (Data Management) (ArcInfo and ArcEditor only)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Unregisters an ArcSDE dataset as versioned in ArcCatalog.
When unregistering a dataset or feature class as versioned in ArcCatalog, a warning may appear informing you that outstanding edits still remain in existing versions. Unregistering the class as versioned will remove all the edits. To preserve the edits, you must compress the database before unregistering the dataset.
Usage tips
Command line syntax
An overview of the Command Line window
UnregisterAsVersioned_management <in_dataset> <keep_edit> {NO_COMPRESS_DEFAULT | COMPRESS_DEFAULT}
Parameter Explanation Data Type
<in_dataset>
Name of the ArcSDE dataset to be unregistered as versioned.
Table View | Feature Dataset
<keep_edit>
Specifies whether edits made of the version should be maintained.
  • KEEP_EDIT — Keep the edits. This is the default.
  • NO_KEEP_EDIT — Do not keep the edits.
Boolean
Determines whether edits will be compressed and unused data will be removed.
  • NO_COMPRESS_DEFAULT — Edits are not compressed. This is the default.
  • COMPRESS_DEFAULT — Edits are compressed.
Boolean
Data types for geoprocessing tool parameters
Command line example
unregisterasversioned_management  "Database Connections\Connection to workspace.sde\v1_vegetation"
Scripting syntax
About getting started with writing geoprocessing scripts
UnregisterAsVersioned_management (in_dataset, keep_edit, compress_default)
in_dataset (Required)
keep_edit (Required)
Boolean
compress_default (Optional)
Boolean
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "Database Connections\Connection to workspace.sde"
gp.toolbox = "management"
gp.unregisterasversioned("v1_vegetation")
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
