Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Multidimensional toolbox > Tools
Feature To NetCDF (Multidimension)
Release 9.2
Last modified November 9, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Converts a point featureclass to a netCDF file.
Usage tips
Command line syntax
An overview of the Command Line window
FeatureToNetCDF_md <in_features> <field {variable} {units}; field {variable} {units}...> <out_netCDF_file> {field {dimension} {units}; field {dimension} {units}...}
Parameter Explanation Data Type
<in_features>
The input feature class.
Feature Layer
The field or fields used to create variables in the netCDF file. Four special fields, Shape.X, Shape.Y, Shape.Z, and Shape.M are available in the drop-down list. They can be used for exporting x-coordinates or longitude, y-coordinates or latitude, Z values, and M values of input features, respectively.
  • field — A field in the input feature attribute table.
  • {variable} — The netCDF variable name.
  • {units} — The units of the data represented by the field.
(String String String; String String String;...)
<out_netCDF_file>
The output netCDF file. The filename must have a .nc extension.
File
The field or fields used to create dimensions in the netCDF file.
  • {dimension} — The netCDF dimension name.
Data types for geoprocessing tool parameters
Command line example
FeatureToNetCDF C:\Data\WLStations.shp "Shape.X xc; Shape.Y yc; Shape.M chainame mile; WL WaterLevel meter; Q Discharge" D:\Data\HydroFile.nc StationID
Scripting syntax
About getting started with writing geoprocessing scripts
FeatureToNetCDF_md (in_features, fields_to_variables, out_netCDF_file, fields_to_dimensions)
in_features (Required)
Feature Layer
fields_to_variables (Required)
out_netCDF_file (Required)
File
fields_to_dimensions (Optional)
Script example
# FeatureToNetCDF.py
# Description: Converts a feature class to a netCDF file.
# Requirements: None
# Author: ESRI
# Create the Geoprocessor object
import arcgisscripting, sys, string, os
gp = arcgisscripting.create()
try:
    # Set local variables
    InFeatures = "C:\Data\WLStations.shp"
    InFieldToVariable = "Shape.X xc; Shape.Y yc; Shape.M chainame mile; WL WaterLevel meter; Q Discharge"
    OutNetCDFFile = "D:\Data\HydroFile.nc"
    InFieldToDimension = "StationID"
    # Process: FeatureToNetCDF
    gp.FeatureToNetCDF (InFeatures, InFieldToVariable, OutNetCDFFile, InFieldToDimension)
except:
    # Print error message if an error occurs
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
