Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Server toolbox > Caching toolset > Tools
Generate Map Server Cache (Server)
Release 9.2
Last modified November 22, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Generates a cache of static image tiles for an ArcGIS Server Map Service.
Usage tips
Command line syntax
An overview of the Command Line window
GenerateMapServerCache_Server <server_name> <object_name> <data_frame> <out_folder> <NEW | PREDEFINED> <STANDARD| CUSTOM> <num_of_scales> <dpi> <tile_width> <tile_height> {FUSED| MULTI_LAYER} {tiling_schema} {tile_origin} {Scale; Scale...} {Layer; Layer...} {thread_count} {ANTIALIASING | NONE} {PNG8 | PNG24 | PNG32 | JPEG} {tile_compression_quality}
Parameter Explanation Data Type
<server_name>
The host name of the ArcGIS Server to use to generate the cache.
String
<object_name>
The name of the Map Service to use to generate the cache.
String
<data_frame>
The map from from the source map document to cache.
String
<out_folder>
The parent directory for this Map Service cache.
String
<NEW | PREDEFINED>
Choose to use a NEW or PREDEFINED tiling scheme. A new tiling scheme can be defined in this tool, or a predefined scheme file (.xml) can be loaded. A predefined scheme can be created by running the Generate Map Server Cache Tiling Scheme GP Tool.
NEW is the default.
Boolean
<STANDARD| CUSTOM>
Set the scale level
  • STANDARD — Auto-generates the scales based on the number defined in the "Number of Scales" field. It will use levels that increase or decrease by half from 1:1000000 and will start with a level closest to the extent of the source map document. For example, if the source map document has an extent of 1:121,000,000 and 3 scale levels are defined, the map service will create a cache with scale-levels at: 1:128,000,000; 1:64,000,000; and 1:32,000,000. This is the default.
  • CUSTOM — Permits the cache designer to create a number of scales defined by the "Number of Scales" field at any scale level desired.
Boolean
<num_of_scales>
The number of scale levels to create in the cache.
Long
<dpi>
The dots per inch of the intended output device. If a DPI is chosen that does not match the resolution of the output device, the scale of the map tile will appear incorrect. The default value is 96.
Long
<tile_width>
The width, in pixels, of output map tiles. Small widths map improve performance of the application requesting tiles from the cache as less data will travel over the wire. However, smaller tile size results in a larger cache size and longer creation time. The default tile width is 512.
Long
<tile_height>
The height, in pixels, of output map tiles. Small heights map improve performance of the application requesting tiles from the cache as less data will travel over the wire. However, smaller tile size results in a larger cache size and longer creation time. The default tile height is 512.
Long
Choose to generate a FUSED or MULTI_LAYER cache:
  • FUSED — Each tile is created as a fused image of all the layers in the source map document.
  • MULTI_LAYER — There is one cache, but it is organized into sub-caches containing tiles from each layer in the source map document.
Boolean
{tiling_schema}
Path to a pre-defined tiling scheme.
String
{tile_origin}
Specify the origin (upper left corner) of the tiling scheme in coordinates of the spatial reference of the source map document. The extent of the source map document must be within (but does not need to coincide) with this region.
String
{Scale; Scale...}
Scales at which to cache the Map Service.
String
{Layer; Layer...}
Layers to include in the cache if MULTI_LAYER cache type is chosen.
String
{thread_count}
The number of MapServer Instances to use while generating the cache.
Long
Choose whether to use antialiasing when rendering the tiles. If ANTIALIASING is chosen, edges of lines, borders, and text will be smoothed. There is a performance cost for this option. No benefit will be gained on raster data.
Boolean
Choose either PNG8, PNG24, PNG32 or JPEG file format for the tiles in the cache. PNG24 is the default.
  • PNG8 — a lossless, 8-bit color, image format that uses an indexed color palette and an alpha table. Each pixel stores a value (0-255) that is used to look up the color in the color-palette and the transparency in the alpha table. 8-bit PNGs are similar to GIF images and enjoy the best support for transparent background by most web browsers.
  • PNG24 — a lossless, three-channel image format that supports large color variations (16 million colors) and has limited support for transparency. Each pixel contains three 8-bit color channels and the file header contains the single color that represents the transparent background. The color representing the transparent background color can be set in ArcMap. Versions of Internet Explorer less than version 7 do not support this type of transparency. Caches using PNG24 are significantly larger than those using PNG8 or JPEG and will take more disk space and require greater bandwidth to serve clients.
  • PNG32 — a lossless, four-channel image format that supports large color variations (16 million colors) and transparency. Each pixel contains three 8-bit color channels and one 8-bit alpha channel that represents the level of transparency for each pixel. While the PNG32 format allows for partially transparent pixels in the range from 0 to 255, the ArcGIS Server cache generation tool only writes fully transparent (0) or fully opaque (255) values in the transparency channel. Caches using PNG32 are significantly larger than the other supported formats and will take more disk space and require greater bandwidth to serve clients.
  • JPEG — a lossy, three-channel image format that supports large color variations (16 million colors) but does not support transparency. Each pixel contains three 8-bit color channels. Caches using JPEG provide control over output quality and size and can be more compact than the PNG format.
String
Enter a value between 1 and 100 for the JPEG compression quality. The default value is 75 for JPEG tile format and zero for other formats.
Compression is supported only for JPEG format. The level of compression will depend on the data, but can also be controlled by changing the compression quality. Choosing a higher value will result in less compression and a higher-quality image. Choosing a lower value will result in more compression but a lower-quality image.
Long
Data types for geoprocessing tool parameters
Command line example
GenerateMapServerCache "myServer" "myMapService" "Layers" "C:\arcgisserver\arcgisscache\" NEW STANDARD "3" "96" "512" "512" FUSED # "0 0" "8000000;4000000;2000000" "Layer1;Layer2" 2 ANTIALIASING "JPEG" "75"
Scripting syntax
About getting started with writing geoprocessing scripts
GenerateMapServerCache_Server (server_name, object_name, data_frame, out_folder, tiling_scheme_type, scales_type, num_of_scales, dpi, tile_width, tile_height, map_or_layers, tiling_schema, tile_origin, levels, layer, thread_count, Antialiasing, cache_format, tile_compression_quality)
server_name (Required)
String
object_name (Required)
String
data_frame (Required)
String
out_folder (Required)
String
tiling_scheme_type (Required)
NEW is the default.
Boolean
scales_type (Required)
Set the scale level
Boolean
num_of_scales (Required)
Long
dpi (Required)
Long
tile_width (Required)
Long
tile_height (Required)
Long
map_or_layers (Optional)
Boolean
tiling_schema (Optional)
String
tile_origin (Optional)
String
levels (Optional)
String
layer (Optional)
String
thread_count (Optional)
Long
Antialiasing (Optional)
Boolean
cache_format (Optional)
String
tile_compression_quality (Optional)
Long
Script example
# Script Name: Generate Fused Map Server Cache
# Description: Generates a fused map server cache using PNG8 image format
# Uncomment sys.argv[] lines to accept arguments from the command line.
# Import standard library modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Set the path to the cache.
# Example: \\\\myServer\\arcgiscache\\MyServiceFolder_MyService\out_folder = "\\\\myServer\\arcgiscache\\MyServiceFolder_MyService\\"
#out_folder = sys.argv[1]
# Set the SOM server name
# Example: "mySOM"
server_name = "mySOM"
#server_name = sys.argv[2]
# Set the object_name
# Example: "MyServiceFolder/MyService"
object_name = "MyServiceFolder/MyService"
#object_name = sys.argv[3]
# Set the data frame
# Example: "Layers"
data_frame = "Layers"
#data_frame = sys.argv[4]
# Set the map cache tiling origin
# Example: "-180 90"
tile_origin = "-180 90"
#tile_origin = sys.argv[5]
# Set the scale levels for the cache.
# Example: "2000000;500000;250000"
scales = "2000000;500000;250000"
#scales = sys.argv[6]
# Set the layers to cache.
# Example: "My First Layer;My Second Layer;My Third Layer"
layers = "My First Layer;My Second Layer;My Third Layer"
#layers = sys.argv[7]
# Set number of instances to use while updating the cache
# Example: "3"
thread_count = "3"
#thread_count = sys.argv[8]
# Set cache tile image format.
# Example: "PNG8"
cache_format = "PNG8"
#layers = sys.argv[9]
# Non-argument variable declarations
tiling_scheme_type = "NEW"
tiling_schema = ""
scales_type = "STANDARD"
num_of_scales = "3"
dpi = "96"
tile_width = "512"
tile_height = "512"
map_or_layers = "FUSED"
antialiasing = "ANTIALIASING"
tile_compression_quality = "0"
try:
    print 'Starting Cache Generation'
    gp.GenerateMapServerCache(server_name, object_name, data_frame, out_folder, tiling_scheme_type,  scales_type, num_of_scales, dpi, tile_width, tile_height, map_or_layers, tiling_schema, tile_origin, scales, layers, thread_count, antialiasing, cache_format, tile_compression_quality)
    print 'Finished Cache Generation'
except:
    gp.AddMessage(gp.GetMessages(2))
    print gp.GetMessages(2)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
