Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Spatial Statistics toolbox > Utilities toolset > Tools
Count Rendering (Spatial Statistics)
Release 9.2
Last modified January 9, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Applies graduated circle rendering to a count type field of a point feature class.
Illustration
Count Renderer illustration
Usage tips
Command line syntax
An overview of the Command Line window
CountRenderer_stats <Input_Feature_Class> <Field_to_Render> <Output_Layer_File> <Number_of_Classes> <mango | bright_red | dark_green | green | dark_blue | bright_pink | light_yellow | sky_blue> {Maximum_Field_Value}
Parameter Explanation Data Type
The feature class containing count data to be rendered.
Feature Layer
<Field_to_Render>
The name of the field containing count data.
Field
<Output_Layer_File>
The output layer file to store rendering information. You must include the .lyr extension as part of the file name.
Layer File
<Number_of_Classes>
The number of classes into which the input feature class will be classified.
Long
The color of the graduated circles.
String
The maximum attribute value that will be rendered. Features with field values greater than this maximum value will not be drawn.
Double
Data types for geoprocessing tool parameters
Command line example
workspace e:\project93\data
CollectEvents assaults.shp assaults_weight.shp
CountRenderer assaults_weight.shp COUNT assaults.lyr 8 bright_red #
Scripting syntax
About getting started with writing geoprocessing scripts
CountRenderer_stats (Input_Feature_Class, Field_to_Render, Output_Layer_File, Number_of_Classes, Symbol_Color, Maximum_Field_Value)
Input_Feature_Class (Required)
Feature Layer
Field_to_Render (Required)
Field
Output_Layer_File (Required)
Layer File
Number_of_Classes (Required)
Long
Symbol_Color (Required)
String
Maximum_Field_Value (Optional)
Double
Script example
# Convert incident data to weighted point data and render
# Import system modules
import arcgisscripting, sys, string, os
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Local variables...
workspace = "C:/project93/data/"
input = "AutoTheft.shp"
input_weighted = "autotheft_weighted.shp"
results_field = "Count"
input_weighted_rendered = "auto_weight_rendered.lyr"
try:
    # Set the current workspace (to avoid having to specify the full path to the feature classes each time)
    gp.workspace = workspace
    # Process: Collect Events...
    gp.CollectEvents_stats(input, input_weighted, results_field)
    # Process: Count Rendering...
    gp.CountRenderer_stats(input_weighted, results_field, input_weighted_rendered, "5", "mango", "#")
except:
    # If an error occurred when running the tool, print out the error message.
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
