Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Environment Settings > General settings
Output extent
Release 9.2
Last modified September 4, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "General settings"
Related Topics
Defined area of interest for results from running tools. In the case of feature data, all input features to a tool that pass through the area of interest will be included in the calculation. For raster data, results from running tools will be contained within the extent set.
The extent is a rectangle, specified by identifying the coordinates of the window in map space.
Usage tips
In ModelBuilder
Command line syntax
An overview of the command line window
Extent <MINOF | MAXOF | value>
Parameters Explanation Datatype
<MINOF| MAXOF | value> Specifies the extent of the study area.
  • MINOF (Intersection of Inputs)—The minimum area common to all inputs; where all layers overlay. This is the default.
  • MAXOF (Union of Inputs)—The maximum extent of all inputs; the combined extent of all inputs.
  • value (As Specified Below)—Specifies the minimum and maximum extent values, or a Snap Raster. At the command line or in a script, specify the values in this order: XMin, YMin, XMax, YMax.
  • Snap Raster—A raster used to ensure the cell alignment of the analysis extent. The lower left corner and upper right corner of the specified analysis extent are snapped to the nearest cell of the snap raster.
String
Data types for geoprocessing tool parameters
Command line example
Extent MINOF
Extent '1 1 512 512'
Extent '1 1 512 512 C:\data\snapraster'
Scripting syntax
An overview of scripting in geoprocessing
Extent (study_area)
MINOF | MAXOF | value (Required) Specifies the extent of the study area.
String
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "h:/workspace"
gp.toolbox = "SA"
gp.Extent = "MAXOF"
gp.Extent = "1 1 512 512"
gp.Extent = "1 1 512 512 C:\data\snapraster"
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
