Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Environment Settings > General settings
XY Resolution
Release 9.2
Last modified September 4, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "General settings"
Related Topics
NOTE: This environment is only applicable to ArcGIS 9.2, or higher.
Specify the XY resolution that will be used for processing and set to the output geodataset.
Learn more about XY resolution
Usage tips
Command line syntax
An overview of the command line window
XYResolution <linear unit>
Parameters Explanation Datatype
<Linear unit> The XY Resolution of a feature class or a feature dataset is the numeric precision used to store the coordinates. The XY Resolution, expressed as a very small distance, refers to the number of significant digits used to store coordinate values.
The default resolution for feature classes created in ArcGIS 9.2 and later releases is 0.0001 meters or its equivalent in map units.
Linear Unit
Data types for geoprocessing tool parameters
Command line example
XYResolution 0.002
Scripting syntax
An overview of scripting in geoprocessing
XYResolution (Linear unit)
Linear unit (Required) The XY Resolution of a feature class or a feature dataset is the numeric precision used to store the coordinates. The XY Resolution, expressed as a very small distance, refers to the number of significant digits used to store coordinate values.
Linear Unit
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "H:\\Tongass"
gp.XYResolution = "0.002"
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
