Show Navigation | Hide Navigation
You are here:
Geodatabases and ArcSDE > Building a geodatabase > Defining the properties of a geodatabase > Geodatabase table properties
Data types in the DBMS
Release 9.2
Last modified May 14, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Geodatabase table properties"
Related Topics
When you create a table or add a field to a table in the geodatabase, fields are created as a specific data type. Data types are classifications that identify possible values for and operations that can be done on the data, as well as the way the data in that field is stored in the database.
When you import data of one type into a field of another data type, you need to understand what the equivalent data types are between ArcSDE and your database management system (DBMS) because it can impact data content. Also, when creating new datasets in ArcGIS, it is helpful to know the equivalent data types between ArcGIS and your DBMS. For example, if you add a floating point (float) column to an existing feature class, that equates to a numeric data type column in a SQL Server database.
NOTE: Moving data from one database to another can cause data types to remap.
Learn how data converts from one type to another
File geodatabase data types are the same as ArcGIS data types. For DBMS products, though, data types can differ. The sections below contain information on how DBMS data types map to ArcGIS data types.
Oracle data types
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to Oracle types in the table below.
ArcGIS data type Oracle data type Notes
OBJECTID NUMBER(38) NOT NULL
SHORT INTEGER NUMBER(4)
LONG INTEGER NUMBER(38)
FLOAT NUMBER(38,8)
DOUBLE NUMBER(38,8)
TEXT VARCHAR2(50)
DATE DATE
BLOB BLOB
GUID CHAR(38)
GEOMETRY ST_GEOMETRY*
NUMBER(38)
SDO_GEOMETRY
Oracle data type depends on the geometry storage specified for the layer.
RASTER BLOB
LONG_RAW
Oracle data type depends on the raster storage specified in the DBTUNE table.
*ST_Geometry is a superclass. The actual data subtype created (such as ST_Multilinestring or ST_Point) depends on what type of feature class you create, such as polygon, line, point, multipoint, and multipatch.
SQL Server data types
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to SQL Server types in the table below.
ArcGIS data type SQL Server data type
OBJECTID INT(4)*
SHORT INTEGER SMALLINT(2)
LONG INTEGER INT(4)
FLOAT REAL
DOUBLE DOUBLE**
TEXT VARCHAR(n)
DATE DATETIME
BLOB IMAGE
GUID UNIQUEIDENTIFIER(16)
GEOMETRY IMAGE
RASTER IMAGE
*NOT NULL
**If scale is set to greater than 0 in ArcGIS, the SQL Server data type will be NUMERIC.
DB2 data types
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to DB2 types in the table below.
ArcGIS data type DB2 data type Notes
OBJECTID INTEGER(4) NOT NULL
LONG INTEGER INTEGER(4)
FLOAT DECIMAL(31,8)
DOUBLE DECIMAL(31,8)
TEXT VARCHAR(n)
DATE TIMESTAMP
BLOB BLOB
GUID CHARACTER(38)
GEOMETRY ST_GEOMETRY ST_Geometry is a superclass. The actual data subtype created (such as ST_Multilinestring or ST_Point) depends on what type of feature class you create, such as polygon, line, point, multipoint, and multipatch.
RASTER INTEGER(4)
Informix data types
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to Informix types in the table below.
ArcGIS data type Informix data type Notes
OBJECTID INT(4) NOT NULL
LONG INTEGER INT(4)
FLOAT DECIMAL(32)
DOUBLE DECIMAL(32)
TEXT VARCHAR(n)
DATE DATETIME
BLOB BLOB
GUID CHAR(8)
RASTER INT(4)
Access data types
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to Access data types in the table below.
ArcGIS data type Access data type Notes
OBJECTID Long Integer OBJECTID is an AutoNumber field.
SHORT INTEGER Integer
LONG INTEGER Long Integer
FLOAT Single
DOUBLE Double
TEXT Text
DATE Date/Time
BLOB OLE Object*
GUID Number
GEOMETRY OLE Object*
RASTER Memo Memo fields can store up to 65,536 characters.
*Object Linking and Embedding (OLE) Objects are objects created in other applications that are linked or embedded in Access. In this case, BLOB and GEOMETRY data types don't exist in Access, so the object is in ArcGIS and linked to the Access database.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
