Show Navigation | Hide Navigation
You are here:
Geodatabases and ArcSDE > Administering ArcSDE geodatabases > Connecting to an ArcSDE geodatabase
Setting up clients for a direct connection
Release 9.2
Last modified December 3, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Connecting to an ArcSDE geodatabase"
Related Topics
About setting up clients
NOTE: ArcSDE Enterprise only
You will first create your database and install ArcSDE. When your database software is installed and the database is created and configured for ArcSDE, you are ready to set up your client machines.
You must configure each client machine from which you want to make a direct connection to the geodatabase. The steps you follow to set up a client machine to connect directly to an ArcSDE Enterprise geodatabase on each supported database management system (DBMS) are detailed below. Click the appropriate link to go directly to that section.
How to set up clients to connect directly
To a geodatabase in Oracle
Oracle Net is required on each client machine you want to directly access your DBMS.
  1. Use Oracle tools to install and configure Oracle Net to connect to an Oracle instance with SQL*Plus.
  2. Follow the directions in your Oracle documentation to install Oracle Net.
  3. Test that Oracle Net was installed successfully by typing the following at a command prompt on the client machine:
  4. sqlplus <user name>/<password>@<Oracle Net service name>
    where <user name> is a valid Oracle user name, <password> is that user's password, and <Oracle Net service name> is the service name of the Oracle database to which you want to connect. (This is usually the global database name.)
    If you get the SQL prompt when you execute the command, the Net client is working and you are ready to go to the next step. If you do not get the SQL prompt, consult the Oracle documentation's troubleshooting information.
  5. For each client machine, there are system environment variables you must set, such as the ORAHOME and Path variables. If necessary, ask your system administrator to find out how to set environment variables on your systems.
  6. Test the connection by adding a spatial database connection from ArcCatalog. Instructions for this can be found in the topic Creating spatial database connections.
Tips
  • Which connection string you type in the Service field of the Spatial Database Connection dialog box is dependent on which Oracle Client software you have installed on the local machine.
  • The sde:oracle** tells the ArcSDE client API which driver you are looking for, not to which database you are connecting. In other words, an Oracle9i driver will connect to an 8i database and vice versa. The drivers differ in the version of Oracle with which they were built.
    If you have Oracle8i client software on the local machine, use:
    sde:oracle
    If you have Oracle9i client software on the local machine, use:
    sde:oracle9i
    For connections from a local machine with the Oracle 10g client, use the syntax:
    sde:oracle10g
    If you have Oracle9i or Oracle 10g client software on the local machine and try to connect with the server string:
    sde:oracle
    you will get the following error message:
    Failed to Connect to Specified Server.  Underlying DBMS Error [ Unknown Error.  No extended error]
  • If you are using multiple geodatabases stored in Oracle, see Using multiple geodatabases within a DBMS to find the correct connection syntax for your service.
  • The password you type in the Password field of the Spatial Database Connection dialog box will have the Oracle Net Service name appended to it:
  • mypassword@<Oracle Net Service name>
  • If you are using ArcSDE 8.3 or lower, set the SDEHOME environment variable to point to the directory in which the client application's dynamically linked library files are stored. For ArcGIS Desktop, this should be the directory directly above the Bin directory in the ArcGIS install location.
  • Top of page
To a geodatabase in SQL Server
  1. Be sure you have a valid installation of the Microsoft Data Access Components (MDAC) on the client machine. If you do not, you will need to install the latest Microsoft Data Access Components. Check msado15.dll in \program files\common files\system\ado or download the component checker from www.msdn.microsoft.com and search for Data Access Downloads.
  2. (MDAC versions beyond 2.8 are included with updates to your operating system, so if your client's operating system is up-to-date, you should have the correct components.)
  3. If you have the SDEHOME environment variable set, make sure there is an etc folder in it. If it is not set, you can add an etc folder in your ArcGIS installation location. This etc folder is where log files containing error messages for direct connections are stored by default.
  4. Test the connection by adding a spatial database connection from ArcCatalog. Instructions for this can be found in the topic Creating spatial database connections.
Tips
  • You can use the dbinit.sde file to set environment variables for direct-connect use, which may be more convenient than setting them via system tools. This file is located in the etc directory of your SDEHOME.
  • See The dbinit.sde file more information.
  • If you are using ArcSDE 8.3 or lower, set the SDEHOME environment variable to point client applications to where the direct connect driver files are stored. For ESRI client applications, the direct connect files are installed in the same directory as the client application's other dynamically linked library files. For Windows applications, this is normally in the bin directory of your client application's install location. To set this environment variable, you must specify the full file path to the directory above the bin directory holding the dynamic link libraries (.DLL files) gsrvrsql, sdesqlsvr, sg, sde, and pe. For example:
  • Variable:	SDEHOME
    Value:  C:\Program Files\ArcGIS\sql
    From an ArcGIS client, set neither and let the search default to: HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\CoreRuntime\InstallDir.
    The direct connect process will search for the appropriate driver in the bin directory of the path specified.
    Top of page
To a geodatabase in DB2
  1. Use the DB2 Configuration Assistant to configure the client to connect directly to a DB2 instance. The Configuration Assistant comes with DB2 and lets you configure and maintain the database objects that you or your applications will be using. It is available as part of the DB2 Administration Client and DB2 Application Development Client. Please refer to DB2's documentation for all information on using the DB2 Configuration Assistant to connect directly to a DB2 instance.
  2. Test the database connection that you created using the Configuration Assistant.
  3. Open the Databases page in the DB2 Configuration Assistant. Select the database with which you want to work and from the Selected menu, click Test Connection. When the Test Connection notebook opens, click the type of connections that you want to test. In the User ID field, type a user ID that can connect to the database. Type the password for the user ID in the Password field. If you do not specify a user ID and password, the system password will be used for the connection. Click Test Connection. The Results page opens, displaying the results of the connection test.
    If the connection is successful, you will get the following message:
    This process creates an entry in the db2cli.ini file that will look like this. This file resides under the %DB2PATH% dir.
    [SDEQUART]
    DBALIAS=SDEQUART
  4. Create a local user account.
  5. For direct connect to work successfully with ArcGIS, a local user with the same user name as specified for the connection to the server must be present on the client machine. This user does not require any special permissions.
    To create a local Windows user, refer to Microsoft's Windows documentation. If you do not create a local Windows user account on the client machine with the same user name and password as the one specified for the server, you will receive the following message when attempting a connection through ArcCatalog:
    Error message received if user account not present on local machine
    For Unix platforms, refer to the platform-specific commands and procedures (for example, useradd).
Tip
  • If you are using ArcSDE 8.3 or lower, set the SDEHOME environment variable to point to the directory where the client applications' dynamically linked library files are stored.
  • Top of page
To a geodatabase in Informix
  1. Install the Informix Client SDK or the I-Connect application on each remote client machine you want to direct connect to your database. This makes the Informix client setup files you need available to you. Consult your Informix documentation for further information or help on how to install these applications.
  2. If the Informix server is running on the same host as the client application, you can skip this step.
  3. Be sure that the user on each client machine you want to connect directly to your database has the Connect permission on the database server.
  4. Set up an ODBC driver connection.
  5. For Windows
    Use SetNet32 to configure the client so that it can work with the available objects. Also use SetNet32 to add a new Informix server.
    For Unix
    Set up the $INFORMIXDIR and add the appropriate database server entry in the sqlhosts file in the $INFORMIXDIR\etc directory.
    Consult your Informix documentation for further information or details on how to set the ODBC driver connection.
Tip
  • If you are using ArcSDE 8.3 or lower, set the SDEHOME environment variable to point to the directory where the client application's .DLL files are stored.
  • Top of page
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
