Show Navigation | Hide Navigation
You are here:
Mapping and visualization > Animation > Building animations
About building animations in ArcGIS
Release 9.2
Last modified January 13, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Building animations"
Related Topics
There are different ways to build animations in ArcGIS depending on the type of animation you want to create. You may only need to create one animation track, such as to animate a layer through time. Alternatively, you can create multiple tracks that will animate together when you play the animation, for example, an animation in which you are navigating through a scene where the surface is changing over time and the scene's lighting is also changing with time.
Sample animation videos
Animating data through time
The following data can be animated through time in the display of ArcMap, ArcScene, or ArcGlobe:
In ArcMap, you can also animate tables, feature class layers, and netCDF layers in a graph.
The track type you'll create to animate through time is a time layer track.
Learn more about animating data through time
Animating the view
The view in ArcMap, ArcScene, and ArcGlobe can be animated in various ways. Common examples include:
The track type you'll create to animate the view is a map view track in ArcMap, a camera track in ArcScene, and a globe camera track in ArcGlobe.
Learn more about animating the view
Animating layer properties
Layers in ArcMap, ArcScene, and ArcGlobe can be animated in various ways. Common examples include:
The track type you'll create to animate layer properties is a map layer track in ArcMap, a layer track in ArcScene, and a globe layer track in ArcGlobe.
Learn more about animating layer properties
Animating scene properties
The scene in ArcScene can be animated in various ways. Common examples include:
The track type you'll create to animate scene properties in ArcScene is a scene track.
Learn more about animating scene properties
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
