You are here:
Mapping and visualization
Animation
Building animations
About animating layer properties
In ArcMap, ArcScene, and ArcGlobe, you can create an animation that changes layer properties such as transparency and visibility. The animation you create is contained within a map layer track, a layer track, and a globe layer track, respectively.
Reasons to create a layer track:
- To make layers transparent so other layers can be seen as the animation progresses. A layer track works well alongside a camera track that might show a navigation through a scene. At a certain point in the navigation, you might want the information in a layer underneath the top layer in the table of contents to show through.
- To turn layers off in the table of contents. You might have an animation that contains two time layer tracks to which different objects (layers) are attached. At a certain point in the animation, you may want to turn off one of the layers so you can see the other layer animated in the display.
- To move a layer (such as a car) along a path.
- To sequentially display data without a time field (create a group animation).
There are several ways to create the layer track in each application. Keyframes can be created using the Create Keyframes dialog box. A layer can be moved along a path in ArcScene, or a group animation can be created.
Layer properties that can be animated
How to animate layer properties
Step 1: Create the layer track
- To remove animation tracks that you have created, click the Animation drop-down arrow on the Animation toolbar and click Clear Animation. All animation tracks are removed.
- If you want to animate a layer through time and you have a field in the attribute table of your layer with time values, you can create a time layer track instead of creating a group animation.
Learn more about animating data through time
- Save animations to animation files often since there is no undo capability in the Animation Manager.
Step 2: Play the animation
- Any feature selections set will be retained during the playing of the animation.
- By default, after playing or previewing an animation containing a layer track, the layer properties will be restored to their state before the animation was played. If you don't want to restore the state of the layer properties after the animation is played or previewed, uncheck Restore state on the Animation Controls dialog box or Restore state after preview on the Time View tab of the Animation Manager.
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
