You are here:
Extensions
PLTS
Creating geodatabases with PLTS
Defining the geodatabase schema
About the Preprocess Repository tool
The Preprocess Repository tool is located on the PLTS toolbar in ArcCatalog. This tool will only update your Spatial Reference and grid levels for the selected model. Once you have updated your model, the next time you run CASE tools on this model, you will want to select the option "Use values from previous run". This will ensure that the modifications you made to the model will be reflected in the new schema.
How to use the Preprocess Repository tool
- Open ArcCatalog.
- Click the Preprocess Repository button
on the PLTS toolbar.
The Set spatial reference and grid sizes for UML model dialog box appears.
- Click Select Model to select the model to pre-process.
The Select UML Model dialog box appears.
You can choose to use an XML, XMI, or database file.
- Click Browse to navigate to your repository or enter your connection string if connecting to SQL Server.
- Click List Models.
- Choose your model.
- Click OK.
The model will take a few minutes to load depending on the size. You can see it loading in the Model Element box.
- Click Define Spatial Reference.
The Spatial Reference Properties dialog box appears.
- Define your coordinate system, x/y, z, and m domains.
NOTE: If your spatial reference does not require an m or z domain, you can uncheck the checkboxes for the m and z domains under step 2 on the Set spatial reference and grid sizes for UML model dialog box.
(See Creating feature datasets for more information.)
- Click OK.
- Define the grid sizes for all feature classes.
- Click Update Spatial Reference and Grid sizes.
When finished, an information message box will appear, and the updated information will be stored back into the repository for future use by CASE tools.
- You can also access the tool by clicking the Start button, pointing to All Programs, pointing to PLTS, and clicking Pre-Process Model.
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
