Aspect |
Release 9.2
Last modified January 3, 2008 |
![]() ![]() ![]() Print all topics in : "Surface (Spatial Analyst)" |
Derives aspect from a raster surface.
Aspect identifies the downslope direction of the maximum rate of change in value from each cell to its neighbors. Aspect can be thought of as the slope direction. The values of the output raster will be the compass direction of the aspect.
Learn more about how Aspect works
Illustration
Usage tips
Command line and Scripting
Aspect is the direction of the maximum rate of change in the z-value from each cell in a raster surface.
Aspect is expressed in positive degrees from 0 to 359.9, measured clockwise from north.
Cells in the input raster of zero slope — for example, flat — are assigned an aspect of -1.
If the center cell in the immediate neighborhood (3 x 3 window) is NoData, the output is NoData.
If any neighborhood cells are NoData, they are assigned the value of the center cell; then the aspect is computed.
Map Algebra
Cells in the input raster of zero slope (flat) are assigned an aspect of -1.
Learn more about how to specify the input raster dataset in the Map Algebra expression of Raster Calculator.
ArcObjects
Valid input for the geoDataset to ArcObjects is a Raster, RasterDataset, RasterBand, or RasterDescriptor.
The output from the ArcObjects method is a raster object.
Command line syntax
An overview of the Command Line window
Aspect_sa <in_raster> <out_raster>
Parameter | Explanation | Data Type |
<in_raster> |
Input raster. |
Composite Geodataset |
<out_raster> |
The raster to be created. |
Raster Dataset |
Aspect_sa C:/data/dem C:/data/aspect
Scripting syntax
About getting started with writing geoprocessing scripts
Aspect_sa (in_raster, out_raster)
in_raster (Required) |
Input raster. |
out_raster (Required) |
Raster Dataset |
# Aspect_sample.py # Description: # Derives aspect from a raster surface. # Requirements: None # Author: ESRI # Date: Sept 6, 2005 # Import system modules import arcgisscripting # Create the Geoprocessor object gp = arcgisscripting.create() try: # Set local variables InRaster = "C:/data/dem" OutRaster = "C:/data/aspect" # Check out ArcGIS Spatial Analyst extension license gp.CheckOutExtension("Spatial") # Process: Aspect gp.Aspect_sa(InRaster, OutRaster) except: # If an error occurred while running a tool, then print the messages. print gp.GetMessages()
Map Algebra syntax
Aspect(<grid>)
<grid> | Any valid combination of rasters, numbers, operators, and functions that produces an output raster. |
aspect(ingrid) aspect(ingrid) * 5 aspect(ingrid1 + ingrid2)
ArcObjects syntax
ISurfaceOp::Aspect (geoDataset As IGeoDataset) As IGeoDataset
geoDataset | An input Raster, RasterDataset, RasterBand, or RasterDescriptor. |
' Create the RasterSurfaceOp object Dim pSurfaceOp As ISurfaceOp Set pSurfaceOp = New RasterSurfaceOp ' Declare the input raster object Dim pInputDataset As IGeoDataset ' Calls function to open a raster dataset from disk Set pInputDataset = OpenRasterDataset ("D:\SpatialData", "inputraster") ' Declare the output raster object Dim pOutputRaster As IGeoDataset ' Calls the method Set pOutputRaster = pSurfaceOp.Aspect (pInputDataset)
