Managing a geometric network(ArcInfo and ArcEditor only) |
Release 9.2
Last modified February 1, 2008 |
Print all topics in : "Creating and managing geometric networks" |
NOTE: Although geometric networks can be both created and edited in ArcInfo and ArcEditor, they are read-only in ArcView.
Some of the standard operations on the geometric network work the same way as other items in ArcCatalog. A geometric network can be copied or deleted. Copying a geometric network persists the network connectivity and feature classes. Deleting a geometric network also deletes the network schema and causes the network feature classes to revert to simple feature classes.
Geometric networks can be copied in two ways: by copying the feature dataset containing the geometric network or by copying the geometric network itself. If the geometric network is copied, the target feature dataset must have the same spatial reference and extent as the source feature dataset.
Geometric networks can be deleted by deleting the containing feature dataset, which will remove the geometric network and any other object stored in the feature dataset, or by deleting the geometric network itself, which will leave the feature dataset and its containing objects intact.
Once your geometric network is deleted, the following changes occur:
Managing network feature classes is more restrictive than managing simple feature classes. While a network feature class's alias can be changed, its name cannot. Deleting a network feature class is also more difficult than deleting simple feature classes. To delete the network feature class, you must first delete the geometric network; this action converts the network feature class to a simple feature class that can then be deleted. The alternative is to delete the entire feature dataset, which deletes the network and all the feature classes.
An exclusive lock is required to modify a geometric network's connectivity rules, add a feature class to the geometric network or delete a geometric network. An exclusive lock can only be acquired for a geometric network if the feature classes that participate in the network can also be locked. Therefore, if a user has an exclusive or shared lock on any of the feature classes in a geometric network, then the properties of the geometric network can't be edited.
Learn more about exclusive locks and schema locking
