This table contains a complete list of two-dimensional spatial relationships available and the keyword used in the Geoprocessing tool versus the ArcMap dialog box.
| INTERSECT |
intersect |
| WITHIN_A_DISTANCE |
are within a distance of |
| CONTAINS |
contain |
| COMPLETELY_CONTAINS |
completely contain |
| CONTAINS_CLEMENTINI |
contain (Clementini) |
| WITHIN |
are within |
| COMPLETELY_WITHIN |
are completely within |
| WITHIN_CLEMENTINI |
are within (Clementini) |
| ARE_IDENTICAL_TO |
are identical to |
| BOUNDARY_TOUCHES |
touch the boundary of |
| SHARE_A_LINE_SEGMENT_WITH |
share a line segment with |
| CROSSED_BY_THE_OUTLINE_OF |
are crossed by the outline of |
| HAVE_THEIR_CENTER_IN |
have their centroid in |
Each graphic shows a spatial relationship (lettered A, B, C) and the accompanying table lists valid spatial relationship types and which cases (A, B, C) would result in the input feature being selected.
WITHIN_A_DISTANCE: This spatial relationship is not included in the graphic examples below. When this option is selected, the features in the Select Features layer are buffered by the distance specified, then the INTERSECT spatial relationship is used.
Clementini spatial relationships
WITHIN_CLEMENTINI and CONTAINS_CLEMENTINI refers to the within and contains spatial relationship as defined in the following paper: Eliseo Clementini, Paolino Di Felice, and Peter van Oosterom, "A Small Set of Formal Topological Relationships Suitable for End-User Interaction,"
Proceedings of the Third International Symposium on Advances in Spatial Databases, pp. 277–295, June 23–25, 1993.
Contrast of the three "contains" spatial relationships
Definition of boundary: For lines, the boundary is the two endpoints; for polygon the boundary is the edge.
- CONTAIN: Selects features in the Input Feature Layer that contain a feature in the Selecting Features layer. The Selecting Features can be inside as well as on the boundary of the Input Feature Layer.
- COMPLETELY_CONTAINS: Selects features in the Input Feature Layer that contain a feature in the Selecting Features layer, as long as the feature in the Selecting Features layer does not intersect the boundary of the Input Feature Layer.
- CONTAINS_CLEMENTINI: The results will be identical to CONTAINS with the exception that if the feature in the Selecting Features layer is entirely on the boundary of the Input Feature Layer, with no part of the contained feature properly inside the feature in the Input Feature Layer, the input feature will not be selected. CLEMENTINI states that the boundary of a point is always empty and the boundary of a line is the endpoints.
- CONTAINS & CONTAINS_CLEMENTINI produce identical results with point and multipoint input, and the Selecting Features are point or multipoint.
Contrast of the three "within/contained by" spatial relationships
- WITHIN: Will select features in the Input Feature Layer that are within or contained by features in the Selecting Features layer.
- COMPLETELY_WITHIN: The result will be identical to CONTAINED_BY unless the feature in the Input Feature Layer intersects the boundary of the feature in the Selecting Features layer; then it will not be selected.
- WITHIN_CLEMENTINI: The result will be identical to CONTAINED_BY unless the entirety of the feature in the Input Feature Layer is on the boundary of the feature in the Selecting Features layer. CLEMENTINI states that the boundary of a point is always empty and the boundary of a line is the endpoints.
Legend
Through the graphic examples below, the following legend applies:
- Input feature: green
- Input feature's center: red "x"
- Select Feature: gray
The graphics are labeled A, B, C, and so forth. Each Relationship (INTERSECT, CONTAINS, etc.) that is valid for that combination of geometries is listed in the left column of the table. The cases that would be selected for that Relationship are listed in the right column of the table.
Select point using point
Select point using point graphic
| INTERSECT |
A |
| CONTAINS |
A |
A |
| WITHIN |
A |
| WITHIN_CLEMENTINI |
A |
| ARE_IDENTICAL_TO |
A |
A |
Select point using multi-point
Select point using multi-point graphic
| INTERSECT |
A, C |
| CONTAINS |
A |
A |
| WITHIN |
A, C |
| WITHIN_CLEMENTINI |
A, C |
| ARE_IDENTICAL_TO |
A |
A, C |
Select point using line
Select point using line graphic
| INTERSECT |
A, C |
| WITHIN |
A, C |
| COMPLETELY_WITHIN |
A |
| WITHIN_CLEMENTINI |
A |
A, C |
Select point using polygon
Select point using polygon graphic
| INTERSECT |
A, C |
| WITHIN |
A, C |
| COMPLETELY_WITHIN |
A |
| WITHIN_CLEMENTINI |
A |
A, C |
Select multi-point using point
Select multi-point using point graphic
| INTERSECT |
A, C |
| CONTAINS |
A, C |
A, C |
| WITHIN |
A |
| WITHIN_CLEMENTINI |
A |
| ARE_IDENTICAL_TO |
A |
A, D |
Select multi-point using multi-point
Select multi-point using multi-point graphic
| INTERSECT |
A, C, E, F |
| CONTAINS |
A, F |
A, F |
| WITHIN |
A, C |
| WITHIN_CLEMENTINI |
A, C |
| ARE_IDENTICAL_TO |
A |
A, D |
Select multi-point using line
Select multi-point using line graphic
| INTERSECT |
A, C, E, F |
| WITHIN |
A, C, E |
| COMPLETELY_WITHIN |
A |
| WITHIN_CLEMENTINI |
A, E |
A, D, E |
Select multi-point using polygon
Select multi-point using polygon graphic
| INTERSECT |
A, C, D, E, F |
| WITHIN |
A, C, D, E |
| COMPLETELY_WITHIN |
A |
| WITHIN_CLEMENTINI |
A, D, E |
A, B, C, E, F |
Select line using point
Select line using point graphic
| INTERSECT |
A, C, D |
| CONTAINS |
A, C, D |
A, D |
A, D |
D |
Select line using multi-point
Select line using multi-point graphic
| INTERSECT |
A, C, D, E |
| CONTAINS |
A, C, E |
A |
A, E |
D |
Select line using line
Select line using line graphic
| INTERSECT |
A, C, D, E, F, G, H, I, J |
| CONTAINS |
G, H |
G |
G, H |
| WITHIN |
F, H |
| COMPLETELY_WITHIN |
F |
| WITHIN_CLEMENTINI |
F, H |
| ARE_IDENTICAL_TO |
H |
| BOUNDARY_TOUCHES |
C, E |
Select line using polygon
Select line using polygon graphic
| INTERSECT |
A, C, D, E, F, G, H, I, J, K, L, M, N, O |
| WITHIN |
A, D, G, H, I, O |
| COMPLETELY_WITHIN |
A |
| WITHIN_CLEMENTINI |
A, D, G, H, I |
| BOUNDARY_TOUCHES |
D, F, G, H, I, K, L, M, N, O |
G, I, J, K, M, O |
C, E, H, L, N |
A, C, D, E, G, H, I, J, O |
Select polygon using point
Select polygon using point graphic
| INTERSECT |
A, B |
| CONTAINS |
A, B |
A |
A |
A, D |
Select polygon using multi-point
Select polygon using multi-point graphic
| INTERSECT |
A, B, C, E |
| CONTAINS |
A, B, E |
A |
A, B |
A, D |
Select polygon using line
Select polygon using line graphic
| INTERSECT |
| CONTAINS |
A, D, G, H, I, O |
A |
A, D, G, H, I |
| BOUNDARY_TOUCHES |
G, I, J, K, M, O |
C, E, H, L, N |
E, I, L |
Select polygon using polygon
Select polygon using polygon graphic
| INTERSECT |
A, C, D, E, F, G, H, I, J, K, M |
| CONTAINS |
C, E, H, M |
C |
C, E, H, M |
| WITHIN |
F, G, H, M |
| COMPLETELY_WITHIN |
F |
| WITHIN_CLEMENTINI |
F, G, H, M |
| ARE_IDENTICAL_TO |
H, M |
| BOUNDARY_TOUCHES |
D, E, G, H, I, J, M |
D, H, I, M |
A, E, G, J, K |
C, E, F, G, H, K, L |
