Raster To Point (Conversion) |
Release 9.3
Last modified November 21, 2008 |
Print all topics in : "Tools" |
Converts a raster dataset to point features.
Usage tips
Command line and Scripting
For each cell of the input raster dataset, a point will be created in the output feature class. The points will be positioned at the centers of cells that they represent. The NoData cells will not be transformed into points.
The input raster can have any cell size and may be any valid raster dataset.
The feature output is assumed to be a shapefile.
The Field parameter allows you to choose which column in the raster dataset will become an attribute in the output point file. The column containing the cell values (VALUE) will become a column with the heading Grid_code in the attribute table of the output feature class.
The following environments affect this tool: current workspace, scratch workspace, output coordinate system, and output extent.
Command line syntax
An overview of the Command Line window
RasterToPoint_conversion <in_raster> <out_point_features> {raster_field}
| Parameter | Explanation | Data Type |
| <in_raster> |
The input raster dataset. The raster can be integer or floating point. |
Composite Geodataset |
| <out_point_features> |
The output feature class that will contain the converted points. |
Feature Class |
| {raster_field} |
The field to assign values from the cells in the input raster to the point features in the output dataset. It can be an integer, floating-point, or string field. |
Field |
RasterToPoint_conversion buildings.tif building_locations Values
Scripting syntax
About getting started with writing geoprocessing scripts
RasterToPoint_conversion (in_raster, out_point_features, raster_field)
| in_raster (Required) |
| out_point_features (Required) |
Feature Class |
| raster_field (Optional) |
Field |
# RasterToPoint_sample.py
# Description:
# Converts a raster to point features.
# Requirements: None
# Author: ESRI
# Date: Oct 20, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
# Set local variables
InRaster = "C:/data/raster1"
OutPointFeatures = "C:/data/raster2point.shp"
# Process: RasterToPoint_conversion
gp.RasterToPoint_conversion(InRaster, OutPointFeatures)
except:
# Print error message if an error occurs
print gp.GetMessages()
Map Algebra syntax
See GridPointShape.
ArcObjects syntax
See RasterDataToPointFeatureData.
