Feature Vertices to Points (Data Management) (ArcInfo only) |
Release 9.3
Last modified March 8, 2012 |
Print all topics in : "Tools" |
NOTE: This topic was updated for 9.3.1.
Creates a point output feature class based on the vertices of the input features. The attributes of the input features are maintained in the output points feature class.
Learn more about how Feature Vertices to Points works.
Illustration
Usage tips
The ORIG_FID field will be added to the Output Feature Class and will be set to the Input Feature's FID.
Input Features can be polygons, lines, or multipoints.
If the input is a multipoint feature class, the output will be a point feature class.
The following environment settings affect this tool: Coordinate system, Extent, XY Tolerance, Z Tolerance, M Tolerance , XY Resolution, Z Resolution, M Resolution , Output XY domain, Output Z domain, Output M domain , Output has M values, Output has Z values, Default Z value , Configuration keyword, and Output Spatial Grid.
Command line syntax
An overview of the Command Line window
FeatureVerticesToPoints_management <in_features> <out_feature_class> {ALL | MID | START | END | BOTH_ENDS}
| Parameter | Explanation | Data Type |
| <in_features> |
Line or polygon features whose vertices will be used to create points. |
Feature Layer |
| <out_feature_class> |
The feature class that will be created and will contain the results. |
Feature Class |
| {ALL | MID | START | END | BOTH_ENDS} |
Specifies which of the Input Feature's vertices will be transferred (as points) to the Output Feature Class. Specified using one of the following keywords:
String |
FeatureVerticesToPoints_management d:\workspace.mdb\roads roads_pt.shp all
Scripting syntax
About getting started with writing geoprocessing scripts
FeatureVerticesToPoints_management (in_features, out_feature_class, point_location)
| in_features (Required) |
Feature Layer |
| out_feature_class (Required) |
Feature Class |
| point_location (Optional) |
String |
import arcgisscripting gp = arcgisscripting.create() gp.workspace = "h:/workspace.mdb" gp.toolbox = "management" try: gp.FeatureVerticesToPoints "roads", "roads_pt.shp", "all" except: print "Error occured while running FeatureVerticesToPoints" print gp.GetMessages(2)
