You are here:
Geoprocessing tool reference
Environment Settings
General settings
Defined area of interest for results from running tools. In the case of feature data, all input features to a tool that pass through the area of interest will be included in the calculation. For data, results from running tools will be contained within the extent set.
The extent is a rectangle, specified by identifying the coordinates of the window in map space.
Usage tips
- The keyword used at the command line or in scripts for this environment setting is Extent.
- Set this environment if your study area is only a portion of a larger dataset.
- The extents entered are assumed to be in the coordinate system in which the data is stored, even if the OutputCoordinateSystem environment is set.
- Extent uses keywords at the command line or in scripting. If you set extent using the environments dialog box, you will notice the keywords are represented with phrases.
| MINOF |
Intersection of Inputs |
The minimum area common to all inputs, where all layers overlay. This is the default. |
| MAXOF |
Union of Inputs |
The maximum extent of all inputs; the combined extent of all inputs. |
| value |
As specified below |
User-specified XMin, YMin, XMax, YMax values. |
| N/A |
Default |
NOTE: This option is available only on the environments dialog box.
- When you first specify the extent to be the same as a layer, the extent is read and set. The next time you open up environments, it will read "As specified below." The numbers come from the previously set layer, but the option reverts to As specified below.
Learn more about specifying general settings.
Learn more about environment settings.
Learn more about environment levels and hierarchy.
In ModelBuilder
- In ModelBuilder, Extent will also show a list of variables. If you create a feature dataset, a raster dataset, a feature layer, a raster layer, or extent variables in your model, you will see these as options in the extent drop-down list. These choices are easily recognizable because they appear as either Same as variable <
name
> or Same as layer <
name
- The list will also show derived data in the drop-down list. Derived data does not already exist before the model is executed and therefore can't be selected as the model extent. So if you are setting the extent for the entire model, do not select derived data.
- You can selected derived data only if you are setting the extent for a single process and the derived data will be created before the process will execute. In your model diagram you will see a condition connector line appear that forces the model to first execute the process with the derived data element.
- In ArcGIS 9.2, extent is dynamic, which allows for the additional selection of feature dataset, raster dataset, feature layer, raster layer, or extent variables. However, if you open the extent environment and click anywhere in the top/bottom/left/right input boxes, the input will display As specified below and the extent will become static. The variable you had selected will no longer define the extent and the connector line will be automatically removed from your model. To make the extent dynamic again, you will need to reset the extent by selecting a drop-down list choice.
Command line syntax
An overview of the command line window
Extent <MINOF | MAXOF | value>
| <MINOF| MAXOF | value> |
Specifies the extent of the study area.
- MINOF (Intersection of Inputs)—The minimum area common to all inputs, where all layers overlay. This is the default.
- MAXOF (Union of Inputs)—The maximum extent of all inputs; the combined extent of all inputs.
- value (As Specified Below)—Specifies the minimum and maximum extent values:
- Left—XMin value
- Right—XMax value
- Bottom—YMin value
- Top—YMax value
String |
Data types for geoprocessing tool parameters
Command line examples
Extent MINOF
Extent '1 1 512 512'
Scripting syntax
An overview of scripting in geoprocessing
Extent (study_area)
| MINOF | MAXOF | value (Required) |
- Left—XMin value
- Right—XMax value
- Bottom—YMin value
- Top—YMax value
String |
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "h:/workspace"
gp.toolbox = "SA"
gp.Extent = "MAXOF"
gp.Extent = "1 1 512 512"
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
