You are here:
Geoprocessing tool reference
Environment Settings
General settings
NOTE: This environment is only applicable to ArcGIS 9.2 or higher.
Specify the M resolution that will be used for processing and set to the output geodataset.
Learn more about M resolution.
Usage tips
- Unlike XY and Z resolution, the M resolution of a feature class inside a feature dataset is not constrained to match the feature dataset's M resolution. For feature classes created inside a feature dataset, the feature dataset's M resolution is used as the default. To override this default, set the M resolution environment to the desired value.
- If the output is a stand-alone feature class, raster catalog, or feature dataset, the tolerance of the input will be used as the processing and set as the output feature class' Z resolution. For tools that have multiple inputs (Intersect, for example) the resolution of the first geodataset in the list will be used as the default. To override these defaults, set the Z resolution environment to the desired value.
- If the tool does not have an input geodataset (for example, Create Feature Class, Create Feature Dataset, and Create Raster Catalog) and if the environment is left blank, the default M resolution is set to 0.001 unit. To override this default, set the environment to the desired value.
Learn more about specifying general settings.
Learn more about environment settings.
Learn more about environment levels and hierarchy.
Command line syntax
An overview of the command line window
MResolution <Linear unit>
| <Double> |
The resolution of m-values when feature classes are created.
The default value is the same as the XY resolution of 0.0001 meter or its equivalent in map units. |
Double |
Data types for geoprocessing tool parameters
Command line example
MResolution 0.002
Scripting syntax
An overview of scripting in geoprocessing
| Double (Required) |
Double |
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "h:/workspace"
gp.MResolution = "0.002"
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
