Creating new shapefiles and dBASE tables |
Release 9.3
Last modified November 19, 2008 |
Print all topics in : "Shapefiles" |
You can create new shapefiles and dBASE tables in ArcCatalog. When you create a new shapefile, you must define the types of features it will contain whether those features will represent routes (m-values) and whether those features will be three-dimensional (z-values). These properties can't be modified after the shapefile has been created. You can also define the coordinate system of the shapefile. If you choose to define the shapefile coordinate system later, it will be classified as Unknown until then.
The process of defining the new shapefile or dBASE table's attributes is separate from creating the shapefile or dBASE table itself. After creating the item, define its attributes by right-clicking it in ArcCatalog and clicking Properties. Because it must contain at least one attribute column, ArcCatalog adds a default column to the shapefile or dBASE table when it is created. For shapefiles, an integer column named Id is added as an attribute. For dBASE tables, an integer column named Field1 is added. Add the appropriate attributes to your shapefile or dBASE table. After the new attributes have been added as part of the shapefile, you can delete the default column if you decide you don't want to use it.
