An overview of 3D Analyst |
Release 9.3
Last modified April 24, 2009 |
Print all topics in : "Getting started with 3D Analyst" |
The ArcGIS 3D Analyst extension provides tools for three-dimensional (3D) visualization, analysis, and surface generation.
With 3D Analyst, users can:
ArcGlobe is one of two applications provided by the 3D Analyst extension and gives you a new and unique way to view and analyze your GIS data. Spatially referenced data is placed on a 3D globe surface, displayed in its true geodetic location. You can manipulate the globe, then investigate and analyze its data while viewing the globe as a whole, or regions within it. You can view data covering a global extent then seamlessly zoom into highly detailed, localized data.
ArcGlobe gives you the power to tame voluminous data while fully employing all information the data can give you. ArcGlobe allows efficient display and query of raster data and is integrated to function with the ArcGIS geodatabase while providing support for analysis in the geoprocessing environment.
Learn more about ArcGlobe.
ArcScene is one of two applications provided by the 3D Analyst extension and allows you to effectively manage your 3D GIS data, perform 3D analysis, create 3D features, and display layers with 3D viewing properties. You can create 3D features from existing two-dimensional (2D) GIS data, or you can digitize new 3D vector features and graphics in ArcMap using a surface to provide the z-values.
ArcScene allows you to make realistic scenes in which you can navigate and interact with your GIS data, as in the following 3D view of utility poles and power lines.
Learn more about ArcScene
In ArcCatalog, the 3D Analyst extension allows you to manage 3D GIS data and create layers with 3D viewing properties. You can preview scenes and data in 3D in ArcCatalog using the same 3D navigation tools you use in ArcScene.
Learn more about 3D Analyst capabilities in ArcCatalog
In ArcMap, the 3D Analyst extension allows you to create new surfaces from your GIS data as well as analyze surfaces, query attribute values at a location on a surface, and analyze the visibility of parts of a surface from different locations. You can also determine the surface area and the volume above or below a surface and create profiles along a 3D line on a surface.
Learn more about 3D Analyst capabilities in ArcMap
