Show Navigation | Hide Navigation
You are here:
Extensions > 3D Analyst > Interactive 3D analysis tools
Creating a line of sight
Release 9.3
Last modified April 24, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Interactive 3D analysis tools"
Related Topics
About creating a line of sight
A line of sight is a graphic line between two points on a surface (raster, TIN, or terrain) that shows where along the line the view is obstructed. The color of the line indicates the locations where the surface is visible and where the surface is hidden. The status bar indicates if the target is visible or hidden.
The Create Line Of Sight tool Line of Sight tool is only available on the 3D Analyst toolbar in ArcMap and works with raster, TIN, or terrain surfaces. Once you've created a line of sight in ArcMap, you can copy and paste the object into ArcGlobe or ArcScene. The line of sight appears in the 3D view as a 3D line that follows the shape of the surface.
Learn more about line of sight and visibility analysis
Line of Sight Example
How to create a line of sight
  1. In ArcMap, click the Create Line Of Sight button Line of Sight tool on the 3D Analyst toolbar.
  2. Optionally, type an observer offset. The observer offset is the eye level of the observer used to determine what is visible from the observer's location. An observer with a height of 0 will have a more obstructed view than an observer with a height value indicated. The height units are the same as the z units of the surface.
  3. Optionally, type a target offset. The target offset is the height of the target point above the surface. A Target with a height of 0 will be less visible than a target with a given height greater than 1.
  4. Optionally, check the box to model curvature and refraction.
  5. For this option to be enabled, the surface must have a defined spatial reference in projected coordinates and defined z units.
  6. First, click on the surface at the observer location, and then click the surface at the target location. A colored line will be drawn indicating what is and what is not visible along the identified path from the observer location.
Tip
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
