Show Navigation | Hide Navigation
You are here:
Extensions > Maplex > Getting started with Maplex
An overview of Maplex
Release 9.3
Last modified January 26, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Getting started with Maplex"
Related Topics
Well-placed labels can make a map more understandable and useful. Maplex for ArcGIS provides a special set of tools that allows you to improve the quality of the labels on your map. With Maplex for ArcGIS, you can define parameters to control the positioning and size of your labels; Maplex for ArcGIS then uses these parameters to calculate the best placement for all the labels on your map. You can assign different levels of importance to features to ensure that more important features are labeled before less important ones, and you can specify size ranges for labels to allow a larger number of smaller labels to be placed in areas where features are densely packed.
Maplex for ArcGIS lets you control how labels should be placed relative to features, how labels can be modified or reduced to allow more label placement when the available space is constrained, and how conflicts between labels are resolved when the available space is limited.
Maplex for ArcGIS seamlessly integrates into the labeling and annotation tools in ArcGIS. Simply selecting the ESRI Maplex Label Engine as the active label engine for your data frame enables Maplex for ArcGIS functionality. Labeling dialog boxes, such as the Label Manager, show Maplex properties for enabled data frames, and the Labeling toolbar is updated with Maplex tools and options. The labels you create using Maplex for ArcGIS can also be converted to annotation and shared and edited in a geodatabase. Generating annotation from labels placed with Maplex for ArcGIS cuts the time to manually edit annotation on maps, increasing your productivity.
Before learning more about Maplex for ArcGIS, it is recommended that you familiarize yourself with the labeling and annotation in ArcGIS.
Learn more about labeling in ArcMap.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
