Troubleshooting network analyses |
Release 9.3
Last modified March 2, 2010 |
Print all topics in : "Performing network analysis" |
In ArcGIS Network Analyst, you may encounter certain error messages or unexpected behaviors. Ensure that you have turned on Errors and Warnings in the Network Analyst Options dialog box to understand the solution operation. You can open the Network Analyst Options dialog box by clicking the Network Analyst menu on the Network Analyst toolbar, then clicking the Options command.
You can refer to the general behavior section below to understand what kinds of errors are reported by ArcGIS Network Analyst and why they occur.
Additionally, the solver-specific behavior section below discusses how Network Analyst solvers behave in different scenarios—for example, what happens during route analysis when the origin is not located on the network.
There are five kinds of errors reported by Network Analyst, as discussed in the table below. The order in which these errors are discovered are as follows:
| Type of issue | Description | Example | Output |
| Errors in definition | The analysis problem is incorrectly defined. |
An error message is generated. No solution is found. |
| Invalid locations | Some or all of the network locations are not located on the network. In such cases, two alternatives exist:
If invalid locations are ignored, a partial solution is found using the located network locations. Additionally, a warning message is generated about the unfound network locations that were ignored. If invalid locations are not ignored, no solution is found and an error message is generated. |
| Cardinality issues | The number of valid locations is less than the minimum number of locations required for the analysis. | During route analysis, there is only one valid network location. | An error message is generated. No solution is found. |
| Reachability issues | Some of the network locations cannot be reached. |
Output depends on the solver and the analysis settings. In some cases, a partial solution with a warning message is found. In other cases, no solution is found, and an error message is generated. |
| User Abort | The user aborts the analysis by pressing the Esc key. | During route analysis, the user presses the Esc key after clicking the Solve button |
An Abort message is generated. |
The following rules apply to each solver:
