An overview of GIS Web map layers |
Release 9.3
Last modified August 6, 2010 |
Print all topics in : "Working with web maps in ArcGIS" |
This topic was updated for 9.3.1.
As a user of ArcView, ArcEditor, or ArcInfo, you have the ability to access and use remote GIS Web services in a number of ways in your GIS desktop applications (e.g., in ArcMap and ArcGlobe). GIS Web services are simple, self-contained applications that run independently of your local computer programs (such as ArcMap, a mobile application, or a Web browser). Like all Web services, GIS services are built to perform a focused set of GIS functions and utilize open Web protocols such as XML and Web services.
Perhaps the most common type of GIS service is a Web map service. Web map services can be added as layers in your documents in ArcMap or ArcGlobe. These special Web map services often provide a solid basemap layer that provides a framework onto which you can overlay and work with your own operational information.
Alternatively, you can also layer in Web map services that provide mission-critical operational information that you need to perform a specific set of tasks. For example, you can bring in a Web map layer containing real-time weather information, locations of crime, traffic conditions, property values, and so on. Users often layer in a Web map service that represents information derived from an analytical geoprocessing service.
You can interact with a Web map layer in ArcMap just as you would with other map layers. You can add Web map layers to your map or globe; pan, zoom, and query Web map layers; and so on.
However, it is common that some functionality is restricted when working with Web map layers. For example, color transparency will be disabled for some image service formats that don't support it. The features contained in most GIS Web map layers are not editable. In others, you cannot change their drawing properties. Instead, you use most Web map layers "as is."
The functional differences depend on the type of GIS server that is used to serve the Web map information and the set of capabilities that the server administrators choose to deploy.
GIS Web map services are published and always available on the Web (either on your local internal intranet or more broadly on the World Wide Web). You only need a connection to the appropriate network to access the Web maps that you wish to use. One clear advantage is that you no longer need to hold all the software functions and map data on your local computer. Instead, you can connect to and use a series of remote GIS Web services that provide these for you.
Like other Web services, GIS Web map services have some important characteristics that influence how they are used. The following topics will help to provide some context on how you should think about your own use of map services with ArcGIS.
The following table lists the types of GIS map services supported in ArcMap and ArcGlobe.
| GIS Server | Service type | The data source used in the service | Notes |
| ArcGIS Server | Map service | ArcMap document (.mxd) | Map services delivered from ArcGIS Server can be cached or dynamic.
Optimized map service | Map service definition file (.msd) | Optimized map services are generated in ArcMap. See Publishing optimized map services for more information. |
Image service | Image files—Refer to Supported raster dataset file formats.
Map layer files (.lyr) for displaying raster datasets. For example, layers can be used to render multiband and DEM raster data sources. Geodatabase rasters—Raster data sources in .mdb, .gdb, and various relational DBMSs Image service definition files—.iscdef files created with the ArcGIS Image Server extension. |
Data sources for image services can include
Globe service | ArcGlobe documents (.3dd) | You can use ArcGlobe to create globe documents (.3dd) that can be served using ArcGIS Server. You can also work with Globe Services in ArcGlobe. The primary client for use of these globes is typically ArcGIS Explorer.
| ArcIMS | Map Service | ArcIMS .axl files | ArcIMS map services are from
In both cases, a map as a georeferenced raster image. |
Feature Service | ArcIMS .axl files | ArcIMS Feature Services deliver point, line, and polygon feature classes as services. See Querying features from an ArcIMS service layer.
The feature data is served from the ArcIMS service and ArcMap rendering tools are used to create the map layer display on the desktop client. |
| KML services for Google Earth and Google Map | Keyhole Markup Language (KML) | .kml files and .kmz files | A KML document contains an organized collection of georeferenced graphics, symbols, and descriptive information.
KMZ files hold KML contents that can be shared among users. KML services can be dynamically served using ArcGIS Server. See KML support in ArcGIS. |
| Open Geospatial Consortium (OGC) Services | WMS |
A Web Map Service delivers maps as imagery in the WMS protocol.
A WMS service may also contain a Styled Layer Descriptor (SLD) to specify how the WMS layer is to be symbolized and portrayed See Adding WMS to ArcMap. |
WFS |
A Web Feature Service serves, queries,and updates features using a GML profile.
See Adding WFS as a feature layer in ArcMap. |
WCS |
A Web Coverage Service delivers imagery with its pixel values (e.g., elevation values for a DEM).
See Adding WCS to ArcMap. |
| ArcGIS Online | Services published with ArcGIS Server, layer packages created with 9.3.1 or more recent, other Desktop files like map documents and layer files. | .lpk files
.lyr files .mxd files .3dd files Web maps and other GIS services Microsoft Bing Maps |
See About ArcGIS Online for more details. |
In most cases, GIS services tend to be much slower than typical access of GIS data from local disk drives. Consequently, as a GIS user, you will be continuously looking for ways to improve performance when using GIS services.
There are a four primary mechanisms that can be used to boost Web mapping performance in your applications:
ArcGIS Server supports a map server cache that is similar to the cached map capability used in Web mapping services such as Google Earth, Google Maps, and Microsoft Virtual Earth. As you zoom in on these map services, they are drawn at the appropriate resolution. Each of these digital maps is generated across the study area (e.g., the country or the whole world) for a range of map scales—essentially one map view for each map scale. The map contents are designed at each map scale to portray information at an appropriate resolution.
ArcGIS supports the use of this same mechanism for map and globe publishing. As an ArcGIS user, you can publish your own digital basemaps, globes, and regional scenes (i.e., instead of the whole planet, you can publish a scene for a smaller area with fewer map scales—say, for Marin County, California, or Ft. Worth, Texas).
Each digital map is essentially a series of maps designed for each map scale. The resulting digital map can be stored as a series of tiled images—one set of image tiles that span the study area for each map scale.
Web maps are designed for use at a range of map scales, with views designed for presentation at each map scale. Progressively, higher resolution information is presented as you zoom in. The layers and their contents change as you change map scales.
Some of these maps have a continuous zoom where you can zoom into any desired map scale or resolution that is supported by the map. Other maps (especially 2D Web maps) have a specific set of map scales that you can zoom to. In many Web map applications, you click on ticks on a scale bar tool to zoom to one of several map scales.
Here is the zoom control from the Web Mapping Application included with ArcGIS Server:
Using this control in ArcGIS Web Mapping Applications, you click on a tick to zoom the map to that scale. Or clicking + and - will zoom in and out one map scale level at a time. In this example, notice that there are a total of eight ticks for zooming to a corresponding map view. Each tick represents a map at a particular map scale level. Your job would be to build a map view for each map scale.
There are similar zoom controls in Google Maps and Microsoft Virtual Earth whose maps scale from global down to street level across a range of 15 to 20 map scales.
