Applying a z-factor |
Release 9.3
Last modified January 13, 2012 |
Print all topics in : "Surface analysis" |
This topic was updated for 9.3.1.
The z-factor is a conversion factor that adjusts the units of measure for the vertical (or elevation) units when they are different from the horizontal coordinate (x,y) units of the input surface. It is the number of ground x,y units in one surface z unit. If the vertical units are not corrected to the horizontal units, the results of surface tools will not be correct.
The z-values of the input surface are multiplied by the z-factor when calculating the output surface. If the x-, y-, and z-units are all the same (in feet, for example), the z-factor is 1. This is the default value for the z-factor. For another example, if your vertical z-units are feet and your horizontal x,y units are meters, you would use a z-factor of 0.3048 to convert your z-units from feet to meters (1 foot = 0.3048 meter).
The correct use of the z-factor is particularly important when the input raster is in a spherical coordinate system, such as decimal degrees. It is not uncommon to perceive the output from Hillshade to look peculiar if the input surface raster is not in a projected coordinate system. This is due to the difference in measure between the horizontal ground units and the elevation z-units. Since the length of a degree of longitude changes with latitude, you will need to specify an appropriate z-factor for that latitude.
If your x,y units are decimal degrees and your z units are meters, some appropriate z-factors for particular latitudes are:
Latitude Z-factor
0 0.00000898
10 0.00000912
20 0.00000956
30 0.00001036
40 0.00001171
50 0.00001395
60 0.00001792
70 0.00002619
80 0.00005156
