About setting distance units |
Release 9.3
Last modified May 14, 2009 |
Print all topics in : "Getting started with editing" |
This topic was updated for 9.3.1.
The map units are the units in which the spatial data in the data frame is drawn. Map units are determined by the coordinate system of the data frame. When editing in ArcMap, all the values you enter will be in map units by default. You can find out the map units used by your coordinate system on the Data Frame Properties dialog box General tab.
Sometimes when creating features using the editing tools in ArcMap, you need to enter values that were recorded in different distance units than the coordinate system of your data.
For example, suppose your data is in a state plane coordinate system and the linear units are U.S. survey feet (1 Foot_US = 0.3048006096 m). You are given measurements in international feet (1 Foot = 0.3048 m). Rather than convert all the measurements, you can type the abbreviation for international foot, "ft", after the measurements, and the tools will convert the distance correctly. You could also change the dataset coordinate system definition to use international feet and type the distances without a unit suffix.
Whenever you are typing a distance into one of the editing tools, you have the option to specify the linear units or simply type a number, which the tool will interpret as being in the dataset's coordinate system units. Distance unit abbreviations only work when your data frame is projected—in other words, your data frame must use a projected coordinate system rather than a geographic coordinate system.
The following sections outline all the distance units supported in ArcMap and describe how to implement them.
| Distance units | Abbreviation | Meters per unit | Description |
| Kilometer | km | 1,000 | 1,000 meters exactly |
| Meter | m | 1 | International meter |
| Centimeter | cm | .01 | 1/100 meter exactly |
| Millimeter | mm | 0.001 | 1/1000 meter exactly |
| Foot | ft | 0.3048 | Standard foot used in the United States. Also known as international foot or imperial foot that was used in most non-U.S. countries before the metric system. |
| Mile | mi | 1,609.344 | Also referred to as a statute mile, equal to 5,280 international feet. |
Nautical
mile |
nm | 1,852 | The nautical mile is a unit of distance used primarily in sea and aviation. The nautical mile is defined as the average distance on the earth's surface represented by one minute of latitude. In 1929, the nautical mile was defined as exactly 1,852 meters, or 6,076.11549 feet, a distance known as the international nautical mile. |
| Chain | ch | 20.1168 | 66 international feet. |
| Yard | yd | 0.9144 | Three international feet. |
| Rod | rd | 5.0292 | 1/4 chain, or 16.5 international feet. |
| Link | lk | 0.201168 | 1/100 international chain, or 66/100 international feet. |
| Inch | in | 0.0254 | 1/12 international foot. |
Survey
foot |
ftUS | 0.3048006096 | The U.S. survey foot is used in the state plane coordinate systems. In the United States, fundamental survey units such as rods, chains, statute miles, acres, sections, and townships all depend on the U.S. survey foot. An exact conversion to meters can be accomplished by multiplying U.S. survey feet by the fraction 1,200/3,937. |
Survey
mile |
miUS | 1,609.3472186944 | 5,280 survey feet |
Survey
chain |
chUS | 20.1168402337 | 66 survey feet |
Survey
rod |
rdUS | 5.0292100584 | 1/4 survey chain |
Survey
link |
lkUS | 0.2011684023 | 1/100 survey chain |
Survey
yard |
ydUS | 0.9144018288 | 3 survey feet |
Decimal degrees, degrees/minutes/seconds, or degrees decimal minutes can be used to specify an x,y coordinate while editing such as when placing a vertex or point with Absolute X,Y or Delta X,Y or when moving a feature, vertex, or topology element to an exact x,y location.
Below are valid decimal degrees, degrees/minutes/seconds, or degrees decimal minutes inputs, which are the same formats used by the Go To XY command.
| -45 | -45 |
| 45 W | 45 S |
| 45.50W | 45.50S |
| W45 | S45 |
| 45 30.5W | 44 30.5S |
| 45° 30'30"W | 45°30'30"N |
| 45 30 30 W | 45 30 30 N |
| -45 30 30 | 45 30 30 |
| 45 30.50W | 45 30.50 |
| -45.50833 | 45.50833 |
You can use conversion constants to convert from one measurement system to another. The measurement system to be converted should be multiplied by the associated conversion constant. For example, to convert feet to centimeters, multiply feet by the conversion constant of 30.48 (27 feet x 30.48 = 822.96 centimeters).
View a table of conversion constants
To view this document, you need a copy of Adobe Reader, which you can download free from http://www.adobe.com/products/acrobat/readstep.html.
