Show Navigation | Hide Navigation
You are here:
Extensions > Spatial Analyst > Spatial Analyst functional reference > Math General (Spatial Analyst)
Exp
Release 9.3
Last modified September 7, 2011
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Math General (Spatial Analyst)"
Related Topics
Calculates the base e exponential of cells in a raster.
Illustration
Illustration 1:
Exp illustration (example 1)
Map Algebra:
OutRas = Exp(InRas1)
Command Line:
Exp_sa InRas1 OutRas
Illustration 2:
Exp illustration (example 2)
Map Algebra:
Command Line:
outRas = Exp("InRas1")
Usage tips
Command line syntax
An overview of the Command Line window
Exp_sa <in_raster_or_constant> <out_raster>
Parameter Explanation Data Type
Input raster or constant value for which to find the base e exponential.
Composite Geodataset
<out_raster>
The raster to be created.
Raster Dataset
Data types for geoprocessing tool parameters
Command line example
Exp_sa C:/data/ras_1 C:/data/final_1
Scripting syntax
About getting started with writing geoprocessing scripts
Exp_sa (in_raster_or_constant, out_raster)
in_raster_or_constant (Required)
out_raster (Required)
Raster Dataset
Script example
# Exp_sample.py
# Description:
#   Calculates the base e exponential of the input on a
#   cell-by-cell basis.
# Requirements: None
# Author: ESRI
# Date: Sept 6, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
    # Set the input raster dataset
    inputRaster = "C:/data/ras_1"
    # Set the output raster name
    outputRaster = "C:/data/final_1"
    # Check out Spatial Analyst extension license
    gp.CheckOutExtension("Spatial")
    # Process: Exp
    gp.Exp_sa(inputRaster, outputRaster)
except:
    # If an error occurred while running a tool, then print the messages.
    print gp.GetMessages()
Map Algebra syntax
Exp(<grid | number>)
(<grid | number>) The input to the function.
  • grid  — An input integer or floating-point raster or an expression resulting in a raster.
  • number  — Any integer or floating-point value or an expression resulting in a number.
Map Algebra example
exp(ingrid)
exp(ingrid1 + ingrid2)
exp(ingrid1 div pi)
ArcObjects syntax
IMathOp::Exp (geoDataset As IGeoDataset) As IGeoDataset
geoDataset An input Raster, RasterDataset, RasterBand, or RasterDescriptor for which to find the base e exponential.
ArcObjects example
' Create the RasterMathOps object
Dim pMathOp As IMathOp
Set pMathOp = New RasterMathOps
' Declare the input raster object
Dim pInputDataset As IGeoDataset
' Calls function to open a raster dataset from disk
Set pInputDataset = OpenRasterDataset ("D:\SpatialData", "inputraster")
' Declare the output raster object
Dim pOutputRaster As IGeoDataset
' Calls the method
Set pOutputRaster = pMathOp.Exp (pInputDataset)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
