About creating geometric networks |
Release 9.3
Last modified July 14, 2009 |
Print all topics in : "Creating and managing geometric networks" |
NOTE: Although geometric networks can be both created and edited in ArcInfo and ArcEditor, they are read-only in ArcView.
Geometric networks are created inside feature datasets. Once a geometric network has been created, you must add feature classes to the feature dataset for that geometric network and assign them roles in the network.
ArcCatalog lets you create a new geometric network from nothing, then design and build up the network from scratch. You can then use editing tools in ArcMap, custom Visual Basic (VB), Visual Basic for Applications (VBA), or C++ code to add features to the geometric network. New feature classes can be added to a geometric network at any time.
The process of creating a network can be summarized in the following steps:
You may already have data from which you want to create a geometric network in your geodatabase. ArcCatalog and ArcToolbox contain tools to create a geometric network from that data.
The process of building a geometric network from existing data can be summarized in the following steps, all performed in ArcCatalog:
Ideally, your data should be clean before you build a network. Clean data means that all features that should be connected in the network are geometrically coincident—that is, no overshoots or undershoots. However, if this is not the case, the data may be snapped during the network building process.
It is important to understand how connectivity is established based on snapping during the network building process and how feature geometries are adjusted to establish that connectivity. The following is a series of examples of how connectivity is established in given scenarios.
In these diagrams, use the key below to identify what types of features are illustrated in each scenario:
When snapping features during network building, it is important to understand how the geometry of features is adjusted when snapping. All or part of any feature in a feature class that was specified as being adjustable in the Build Geometric Network wizard can be moved. Those features in feature classes that are not adjustable will remain fixed throughout the network building process.
All features in all feature classes have equal weights when being adjusted during snapping. This means that if the endpoints for two edges need to be snapped and both features can be adjusted, then they will move an equal distance to snap together. If one of the features is not adjustable, then only the adjustable feature will move to snap to the static feature.
When building a geometric network from existing simple feature classes, illegal network geometries may be encountered in some of the input feature classes. Instead of failing when an illegal geometry is encountered, the network builder creates an instance of the feature as a network feature but will not create any network connectivity for that particular feature. If this occurs, a warning message is displayed at the end of the network building process, and a table is created in the database to record these errors.
The warning message will report the total number of illegal features in each network feature class. The error table's name will be <geometricnetwork_name>_BUILDERR. The network building error table's schema is shown in Network build errors table schema.
ArcMap has tools that allow you to use the network build error table to identify these illegal features (see Identifying geometric network build errors). Once you have identified the features and repaired their geometries to be legal geometries, you can use the Rebuild Connectivity tool to repair the network connectivity for those features (see About editing geometric network features).
The network build error table will only show those features that have illegal network geometry at the time the network was built. If you repair these features, or if other features are created in the network with illegal geometries, the network build error table will not be updated. Once you have fixed the geometry of the features reported in this table, it is no longer needed and can be deleted using ArcCatalog.
There are a number of tools and commands in ArcMap to help you identify and repair network features with illegal geometries and with inconsistent network connectivity.
Click the links below to learn more about these tools and commands:
Learn about editing geometric network features.
Verify Network tools and commands.
An exclusive lock is required on all the input feature classes when building a geometric network. If any of the input feature classes has a shared lock, the network will not be built.
If any of the feature classes in a network has a shared or exclusive lock, that lock is propagated to all the other feature classes in the network.
Learn more about exclusive locks and schema locking.
